Decking the Head???
Old Apr 28, 2002 | 11:06 AM
DelsolVtec18's Avatar
New User
Default Decking the Head???
What does it mean to deck the head??? When and why do you need to deck your head???Thanks in advance
Old Apr 28, 2002 | 12:48 PM
riceboy's Avatar
Default Re: Decking the Head??? (DelsolVtec18)
mill a head, deck a block
Old Apr 29, 2002 | 02:32 AM
acuracing's Avatar
You do it to create a flush fit between the head and block.
Old Apr 29, 2002 | 04:45 AM
MrFatBooty's Avatar
Decking the block is a process by which you make the surface that mates to the head (the deck) perfectly flat.
Milling the head is similar, sometimes people shave off a certain thickness to raise CR. Throws off your cam timing a bit when you do that though so adjustable cam gears are needed.
Old Apr 29, 2002 | 08:49 AM
riceboy's Avatar
Default Re: Decking the Head??? (MrFatBooty)
Decking is also a process used to increase deck highth, allowing you to use a longer rod or longer stroke.
Old Apr 29, 2002 | 09:40 AM
MrFatBooty's Avatar
Default Re: Decking the Head??? (riceboy)
Ah true, forgot about that. Is there any particular term for adding height to the deck or is any flattening of the surface considered "decking"?
Old May 9, 2002 | 03:40 PM
InfamousRS's Avatar
Who can deck a block, is there any companies out there that do?
Old May 9, 2002 | 04:16 PM
JCushing's Avatar
Default Re: Decking the Head??? (InfamousRS)
local auto machine shops can do it. while your at it get your crank/crank pully fw balanced too.
Old May 9, 2002 | 04:27 PM
InfamousRS's Avatar
Default Re: Decking the Head??? (JCushing)
Right now I am just dreaming. I would like to get a 95mm Eagle crank, Custom crower rods, custom crower pistons, and the 87mm bore(largest possible according to Golden eagle. But would also like a perfect rod/storke ration.
Would golden eagle still be able to sleeve the block with taller sleeves?
Old May 10, 2002 | 04:35 AM
Tbone's Avatar
If you have a deck plate welded onto your block , you should take into consideration how sleeves are pressed into the block and use the inner side walls of the block to hold the cylinders in place. You would be putting alot of pressure on the deck plate because GE sleeves have that top rib that hold them in place. Am i making any sence to you guys? Do you see where I'm headed with what I'm saying. save your self the troube and try to get one of the Dart/payn blocks with the increased deck height allready installed. Also you better take into consideratin the fact that you are going to have to do alot to get a good headgasket seal with a 87 mm bore, it doesnt leave any room in between the cylinders. Hope this isnt for the street.
Old May 10, 2002 | 05:32 AM
sgT's Avatar
sgT
Default Re: Decking the Head??? (Tbone)
sucks that the dart blocks arent legal for any type of competition.
Old May 10, 2002 | 08:14 PM
InfamousRS's Avatar
Oh, Im just dreaming, it will never really happen.
Old May 10, 2002 | 08:59 PM
qtiger's Avatar
I'm not sure why everyone's all excited about the Eagle cranks. You'd need a hell of a lot of power to worry about a Honda crank breaking.
Old May 10, 2002 | 09:59 PM
InfamousRS's Avatar
Default Re: Decking the Head??? (qtiger)
Its not about the crank being stronger, its that the eagle crank has a 95mm stoke!!!!! Thats 6mm more then a b18a/b!!!!
makes it possible to make one BIG b series!!!!
Old May 10, 2002 | 10:46 PM
.Ryan's Avatar
Don't Trust Anyone
Getting Head while laying out on the sun deck.
eilyassalimjaan
May 23, 2011 06:25 AM
Christopherian1982
Feb 26, 2009 05:42 AM
aimmotorsports
Feb 9, 2008 02:45 PM
wantboost
Welding / Fabrication
48
May 23, 2006 03:03 PM
