Turbonetics manifold with precision turbo?
Old Sep 2, 2006 | 04:39 PM
nick91civicsi's Avatar
Default Turbonetics manifold with precision turbo?
I have a manifold from a turbonetics kit and i was planning on using it with a precision gt30r turbo but i noticed that the flange on the manifold and the one on the turbine are different sizes. i took a picture with the gasket from the manifold over the turbine to show what i mean. My question is wether or not this will cause problems and if there is any way to make it work...
thanks
Modified by nick91civicsi at 2:02 AM 9/3/2006
Old Sep 2, 2006 | 04:44 PM
mrlegoman's Avatar
Default Re: Turbonetics manifold with precision turbo? (nick91civicsi)
I think a good welder could make that work without a problem.
jmo. Maybe ask the guys in the welding forum.
Old Sep 2, 2006 | 04:50 PM
b18ccivics's Avatar
Default Re: Turbonetics manifold with precision turbo? (mrlegoman)
i dont see a problem
Old Sep 2, 2006 | 05:04 PM
im just concerned with how much this will disturb the air flow but if its not a big problem than i ll just use it as is....
Old Sep 2, 2006 | 05:13 PM
mrlegoman's Avatar
Default Re: (nick91civicsi)
Ah, I see. I was looking the picture wrong (sorry I'm tired)
Well, there is going to be some turbulence there. I seriously don't think you will notice any performance issues.
I would recommend at least smoothing out the sharp edge. If it was mine, I'd grind the whole thing down to meet flush like a port and polish on an intake manifold.
Old Sep 2, 2006 | 05:15 PM
inspyral's Avatar
Should be fine.
Old Sep 2, 2006 | 05:43 PM
well i thought about grinding it down a bit but im worried about the metal shavings getting into the turbine and thats a whole other mess that i would not want to deal with... so is this a common thing or is it supposed to be the same size on both?
Old Sep 2, 2006 | 07:04 PM
StolenTeg's Avatar
Take the exhaust housing off
Old Sep 3, 2006 | 12:55 AM
Default Re: (StolenTeg)
well , since i dont have much experience with turbos im reluctant to take it apart at all but if it is a simple process that would be hard to mess up than i might go ahead and do it...
Old Sep 3, 2006 | 01:22 AM
rudebwoy's Avatar
take off the housing and port it, my friend did this to his sc61, I say expletive it aint important
Old Sep 3, 2006 | 08:25 PM
mrlegoman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nick91civicsi &raquo;</TD></TR><TR><TD CLASS="quote">well , since i dont have much experience with turbos im reluctant to take it apart at all but if it is a simple process that would be hard to mess up than i might go ahead and do it...</TD></TR></TABLE>It should be six bolts and your done. I took my housing off a couple months ago and it was a piece of cake.
Old Sep 3, 2006 | 09:04 PM
tannerLSt's Avatar
ME LOVE U LONG TIME
Default Re: (mrlegoman)
housing comes off with ease, just a few bolts and it should slide off, your not actually taking apart, important parts are inside the bearing housing
Old Sep 3, 2006 | 11:57 PM
Flashmn's Avatar
Default Re: (tannerLSt)
unless its rusty.. but if its a new turbo, that wouldnt be the case. I had to use a hammer to drive my exh. housing out.
Old Sep 4, 2006 | 05:06 AM
mrlegoman's Avatar
Default Re: (Flashmn)
Old Sep 5, 2006 | 03:23 PM
hmmm ok well that sounds simple enough so the question is, is it really going to make a diff enough to go through the trouble of doing all this?....
rich7777
Feb 14, 2011 12:11 AM
RubenPrelude
Feb 28, 2008 07:34 AM
mattb16a1civic
Sep 9, 2003 06:46 AM
austrian type-R
Aug 10, 2002 03:16 AM
Integra_Boi
Jul 13, 2002 08:12 PM
