Oil pump shattered?
Old Sep 1, 2006 | 11:36 PM
White_EK49's Avatar
Default Oil pump shattered?
very strange. my oil pressure is zero. after taking the oil pressure sending unit out in back of my B16B. i thought it would be a great idea, perhaps something is blocking the sending unit. yet, nothing. a big hole 1/4 wide and no oil is pumping out. I am leaning toward a blown oil pump. Any ideas. I was trying to prime the oil return line to the turbo before hooking it up.....the motor is mechanical so it should not need anything else but power to crank... Open to all suggestion and intelligent reasoning.
Old Sep 2, 2006 | 07:08 PM
Runnerdown's Avatar
Default Re: Oil pump shattered? (White_EK49)
How long did you crank it for. It can take quite some time to build up enough pressure to close the switch, or leak out in your case.
Old Sep 2, 2006 | 08:52 PM
White_EK49's Avatar
Default Re: Oil pump shattered? (Runnerdown)
How long are we talking about? 30 second or couple of minute. Keep in mind the motor did have oil pressure before. I drained all the oil and when i took off the oil filter, usually their is a residual left in the oil filter and will drain out. This time nothing drain and the oil filter had minimal oil in it.
Old Sep 2, 2006 | 09:29 PM
qfast817's Avatar
i can crank my motor for 30 seconds and it builds up to 10 psi
Old Sep 2, 2006 | 09:39 PM
Garage 808 Hatch's Avatar
was it running before??? i shattered a oil pump with a ctr crank pulley on my car
Old Sep 2, 2006 | 09:47 PM
White_EK49's Avatar
Default Re: (Garage 808 Hatch)
it was running before. just did an oil change.
Old Sep 3, 2006 | 09:15 AM
White_EK49's Avatar
Default Re: (White_EK49)
could it just be a oil pickup gasket.
Old Sep 4, 2006 | 12:44 AM
or a clogged pickup???
adictionbass
Mar 24, 2006 12:44 PM
crxsiperf
Nov 23, 2005 04:36 PM
ham
Jul 26, 2004 06:26 PM
justinCO
Oct 28, 2002 01:07 PM
G
Aug 19, 2001 06:02 PM
