compression and leakdown test results
Old Sep 1, 2006 | 10:32 PM
Brad's Avatar
Default compression and leakdown test results
My compression and leak down results are:
1: 170 15%
2: 165 40% w/ air from the valve cover breather/dipstick/catch can
3: 165 60% w/ bubbles from the radiator
4: 165 15%
So it looks like the head gasket is blown. And probably #2 has bad rings, but I was wondering why the compression test results on #2 isn't lower than the others?
Thanks,
Brad
Old Sep 1, 2006 | 10:45 PM
Jim Truett's Avatar
Default Re: compression and leakdown test results (Brad)
What engine is this?
I would put some oil in #2 and re-check compression.
Old Sep 3, 2006 | 02:37 PM
Brad's Avatar
Default Re: compression and leakdown test results (Jim Truett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett &raquo;</TD></TR><TR><TD CLASS="quote">What engine is this?
I would put some oil in #2 and re-check compression.</TD></TR></TABLE>
It's a b20vtec w/ je 9:1 pistons. I added oil to #2 and the compression test read 185...
Old Sep 8, 2006 | 02:13 PM
K-EG's Avatar
Do you do 2 test when compression testing.I usually do 1 wet test and 1 dry test.
Type 56
Oct 12, 2016 11:10 AM
SilkyJohnson
13
Feb 15, 2011 05:54 PM
GSR_hatch936
Apr 5, 2007 11:04 AM
Got_soy
28
Aug 8, 2005 12:49 PM
gsr~hatch
Apr 17, 2003 03:19 PM
