poping out of gear!
Old Sep 1, 2006 | 12:59 PM
JDM-EJ698's Avatar
Default poping out of gear!
The problem it has now is that it pops out of fifth gear after a short time (10-20 minutes) and that it sometimes pops out of fourth gear after crusing for long rides.it does not grind.what can it be???its a 00'Si tranny
Old Sep 1, 2006 | 01:00 PM
EGwhat!!!'s Avatar
Default Re: poping out of gear! (JDM-EJ698)
low on tranny fluid
Old Sep 1, 2006 | 01:08 PM
JDM-EJ698's Avatar
Default Re: poping out of gear! (EGwhat!!!)
changed it out already.put in about 2qt of honda mtf.
Old Sep 1, 2006 | 01:14 PM
EGwhat!!!'s Avatar
you should double check it.. and check if you have a leak.. if its not that then its time for a new tranny
Old Sep 1, 2006 | 01:16 PM
kuja396's Avatar
I was always under the impression that popping out of gear = worn out transmission. I have No tech input on that, its just what my dad always said
Old Sep 1, 2006 | 01:19 PM
EGwhat!!!'s Avatar
Default Re: poping out of gear! (kuja396)
it could mean that but sometimes its just your low on tranny fluid i have that problem with my current tranny it has a little leak and when it starts popping out of gear in 5th i know its time to fill up again.. i know its not the right thing to do but i got to live with it for now till i save enough for a new tranny
Old Sep 1, 2006 | 01:33 PM
JDM-EJ698's Avatar
there is no leaks that I can see but check more on it when I put on the lift when I get home.the tranny was just rebuilt w/carbon coated syncros.it only has about 30k miles on it.thats normal driving and the ocasional running.
Old Sep 1, 2006 | 03:17 PM
YodajdmEK4's Avatar
Same thing happen to me before and one day the tranny just went, its either the clutch going out but most likely its time for a new tranny, when mine broke I had to replace the tranny. You can still drive like that for some time but one day it will just give.
Old Sep 1, 2006 | 03:26 PM
sohctodohc's Avatar
meh dont worry bout the tranny i have bout 15-20k on a bad clutch housing bearing. its so hollowed out its nasty when i downshift you can hear gears howling and reverse sounds like a virgin girl getting laid for the first time it whines sooooo loud. hehe yea its ok its a honda
MrExclusive
Feb 4, 2010 07:52 AM
jimboek
17
Apr 26, 2007 03:48 PM
B16Jacques
Sep 17, 2006 09:26 PM
SimbaDogg
Feb 22, 2004 10:11 AM
markv
Oct 25, 2003 03:40 PM
