how do you relieve fuel pressure?!?!?
Old Sep 1, 2006 | 10:46 AM
baboracus's Avatar
Default how do you relieve fuel pressure?!?!?
Alright... I can't find the fuel pump fuse (none of the fuses are labeled under the hood) and there's no valve on the fuel rail..... does anyone know which fuse is for the fuel pump on a 90 civic si!??!
Old Sep 1, 2006 | 10:55 AM
Loserkidwac's Avatar
Default Re: how do you relieve fuel pressure?!?!? (baboracus)
Look at the top of your fuel filter...trace the fuel line from the fuel rail to the fire wall...there is a small bolt on the to that you can crack open to relieve fuel pressure
Old Sep 1, 2006 | 11:03 AM
baboracus's Avatar
Default Re: how do you relieve fuel pressure?!?!? (Loserkidwac)
ah i don't see it... how about a fuse panel diagram for the under hood fuses!?!?!?
Old Sep 1, 2006 | 11:42 AM
eda6's Avatar
remove gas cap and put a rag/papeer towel under the fpr and loosen the two nuts on the fpr.
Old Sep 1, 2006 | 11:46 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
{ignore the red line and circle...}
Look on the left side of this pic below the middle of it..
See the round white faced gauge?
That is where the bolt will be in a stock configuration...
Old Sep 1, 2006 | 12:57 PM
daidilus's Avatar
look in the fuse box under the hood, remove the ECU fuse, and crank the car a coupla times,
Old Sep 1, 2006 | 01:03 PM
RCautoworks's Avatar
Default Re: (daidilus)
Just let sit for 15 mins
Old Sep 1, 2006 | 04:03 PM
nappyroots827's Avatar
Default Re: (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Just let sit for 15 mins</TD></TR></TABLE>
my car holds fuel pressure for hours
Old Sep 1, 2006 | 04:04 PM
Default Re: (nappyroots827)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nappyroots827 &raquo;</TD></TR><TR><TD CLASS="quote">
my car holds fuel pressure for hours</TD></TR></TABLE>
Put a rag over bolt, unbolt bolt. Its not like its 100 psi .
Old Sep 1, 2006 | 05:50 PM
crxnj's Avatar
just take off the gas cap..pretty simple
Matt_ek4
Apr 19, 2018 09:34 PM
gratua
Dec 22, 2011 12:35 PM
laughinxxx
Mar 1, 2006 06:06 PM
NoDestinationSi
Mar 16, 2005 02:35 PM
Teal95Coupe
Nov 28, 2001 07:53 PM
