fuel pump fuse
fuel pump fuse
I just bought a b&m fpr. The instructions say i need to remove the fuel pump fuse but i have no idea which one that is. If anybody knows which fuse that is it would be apreciated.
Thanks
Thanks
Re: fuel pump fuse (NoDestinationSi)
it should say it on the back of the fuse box cover under the dash or on top under hood but to install that dont worry about it just install it make sher car is off nuttin should happen i do it all the time.
Anyone else know if this is truly safe? Wont the extra fuel pressure built up in the system spray fuel everywhere? If anyone knows for sure it would be great to hear from you.
thanks
thanks
they want you to relieve the pressure from the fuel system by removing the fuse and cranking the motor or letting it run till it dies(shouldnt be long) its allways a good idea to do this but its not going to make that much of a mess. it wont have more the 45psi once its off.
