Trouble reading ECU codes
Old Apr 28, 2002 | 02:18 AM
CivicEx95's Avatar
Default Trouble reading ECU codes
Put a GSR into my EX. I'm getting a check engine light, but when I jumper the pins, and turn the key to "On" it doesn't flash, just stays solid. What am I doing wrong? Is it not storing the codes for some reason? How do I figure out whats wrong? Thanks.
Old Apr 28, 2002 | 02:25 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: Trouble reading ECU codes (CivicEx95)
How do you know you're getting a code? is the MIL light on?
Are you jumpering the right wires? It's a 2 pin plug, usually brown in color. Not the 3pin one, don't jump that.
Also, make sure you are making good contact with the wires, I've done it many times, and if I don't get the paperclip just right, it does nothing.
HTH
Old Apr 28, 2002 | 04:06 AM
infuryum's Avatar
Default Re:
The plug also comes in green. I've also plugged in the paper clip many times and had no results. It just wasn't in all the way. Be sure it's the right plug and be sure the metal paper clip is in all the way.
Old Apr 28, 2002 | 11:26 AM
flat-blk-HB's Avatar
Default Re: Re: (integral)
try checking your ground on your thermostat housing. I had the same problem with my civic when i did my swap. the check engine light woiuld come on but it wouldn't throw any codes.Then i tightened the bolt on the housing and it started and the CELwent away. You are the one with the problem getting the car yto start too right????
Old Apr 28, 2002 | 12:05 PM
CivicEx95's Avatar
Default Re: Re: (89-ED-bcumbie)
Yeah, but the car is running, but its not running right. I posted about it here https://honda-tech.com/zerothread?id=173959
Old Apr 28, 2002 | 04:37 PM
CivicEx95's Avatar
Default Re: Trouble reading ECU codes (B18C-EJ1)
The MIL light is on when driving the car normal. Now, which one of these plugs do you jumper? I've tried both of the brown ones, and the light just stays on solid, it doesn't flash and show any codes at all.
Old Apr 28, 2002 | 06:17 PM
B18C-EJ1
Guest
Posts: n/a
None of the above. Where did you find those?
The one you want is above the computer and usually strapped to a harness.
Old Apr 28, 2002 | 07:11 PM
CivicEx95's Avatar
Hey, thanks B18C-EJ1. I wasn't looking at the right one. It was way further up there. Anyways, I'm getting 3 codes.
10 - Intake Air Temperture
14 - Idle Air control
20 - Electrical load detector
I'm going to follow the troubleshooting steps in the Helms manual and see what I can do. Any other suggestions? Thanks.
Old Apr 28, 2002 | 09:18 PM
Soku1kcivic's Avatar
10-make sure u plug in the intake temp on the manifold,14-i dont no about this one i changed my ECU to P30 works fine,20 open your fuse box in ur engine bay and flip it over where all the plugs and check the fuse thats where ur ELD
Old Apr 28, 2002 | 09:34 PM
CivicEx95's Avatar
Default Re: Trouble reading ECU codes (Soku1kcivic)
Hey thanks Soku1kcivic! I noticed that the IAC and the IAT have the same connector, and they were reversed . Also, I replaced the heater fuse that blew, and the code 20 went away (don't know if that would do anything.) After doing that, reset the ECU, and now I'm only getting code 10. I looked in my civic helms manual, and the wire colors are correct for that sensor. Now I need to find a multimeter and test the wires and stuff. Am I missing something here?
[Modified by CivicEx95, 6:35 AM 4/29/2002]
VtecCivic93
Sep 2, 2009 10:06 PM
righteyeblind
Jun 30, 2008 01:50 PM
Niskyspy
13
Mar 10, 2008 05:54 PM
Atreyu57
May 16, 2006 12:19 PM
allmotorEG-SI
Jul 20, 2004 09:51 PM
