CEL- Knock Sensor, also fuel injectors
Old Aug 31, 2006 | 02:19 PM
instrument's Avatar
Default CEL- Knock Sensor, also fuel injectors
Hey, i have a CEL for knock sensor, and 1 for fuel injectors.
This is on a VX with a OBD2 b18c running the obd1 p72 ecu.
First, should i check for individual failures on the fuel injectors?
The car occasionally sputters in lower rpm's, but runs fine when accelerating.
I recently changed the fuel filter.
Next the knock sensor, does this mean that it's failed or improperly wired? i moved the blue/yellow wire from the six plug to the ten, was this correct? I alsoused one of those duel crimps to attach the KS wire, should i just solder and shrink wrap it?
thanks guys
Old Aug 31, 2006 | 03:28 PM
b18ccivics's Avatar
heat shrink and solder any connections, and what year car is this?
Old Aug 31, 2006 | 05:20 PM
instrument's Avatar
it's a 94 vx
Old Aug 31, 2006 | 06:02 PM
instrument's Avatar
can anyone help with the injector CEL?
Old Aug 31, 2006 | 06:07 PM
EGwhat!!!'s Avatar
Default Re: (instrument)
double check your wiring and here is a thread that will give you a run though
https://honda-tech.com/zerothread?id=644434
Old Aug 31, 2006 | 06:47 PM
instrument's Avatar
eg, thanks i already have that one... i was just looking for a way to trouble shoot the code itself.... am i getting it because its hooked up wrong or because the ks itself is faulty?
Old Aug 31, 2006 | 09:17 PM
instrument's Avatar
so i guess no one has ever had these cel's before ehhh
axtran's Avatar
when i had an injector cel it was because i was using d16y7 injectors (like an idiot). then it happened again down the line and turns out it was a bad ecu.
Old Aug 31, 2006 | 09:21 PM
instrument's Avatar
Your search for knock sensor cel returned 41 results.
i think i spelled something wrong last time....
axtran, thanks for the help
Old Sep 1, 2006 | 12:08 PM
instrument's Avatar
soldered and shrink wrapped wires...still getting cel.... how can i actually test if i have a good connection?
Old Sep 1, 2006 | 03:17 PM
instrument's Avatar
cel has dissapeared for ks......now on to the fuel injectors.
Old Sep 1, 2006 | 09:38 PM
axtran's Avatar
for fuel injectors try to trace wires back, wiggle at ecu side to check connections too ... might have some issue with your ECU try another one if you can
Powered By Garrett
Mar 30, 2008 12:05 PM
flatblack-h22
Sep 3, 2007 08:55 PM
petarr
Mar 4, 2006 10:37 AM
jdmpremonition
13
Feb 24, 2006 10:37 AM
