running with no thernostat?????
Old Aug 31, 2006 | 09:12 AM
camo_crx's Avatar
Default running with no thernostat?????
what are some pov on this topic. i recently took mine out on my gsr swapped crx. the reason being, my temp gauge would registar kinda hott espically if driving on the freeway for more then 20 minutes. but if i turned the lights off, the temp would go down. and it would fluciate there after. unfortunatley, this problem continues even after removal of the thermostat.
Old Aug 31, 2006 | 11:42 AM
IRONlung201's Avatar
Default Re: running with no thernostat????? (camo_crx)
its just a bandaid for a cooling issue that needs to be addressed.
1. Look for coolant leaks.
2. Check for obvious signs of headgasket failure (Coolant/oil).
3. Check condition of rad cap.
4. Check condition of radiator, and operation of cooling fan.
5. Verrify the car is actually running hot, and is not just a gauge error.
I can go on and on.
Old Aug 31, 2006 | 09:38 PM
camo_crx's Avatar
i actually think its a gauge error. but havent data logged it to see.
Old Aug 31, 2006 | 10:37 PM
Default Re: (camo_crx)
cool, if it seems like a gauge error, id start by checking out your grounds. A friends car had a very similar problem due to a faulty ground in the engine bay, I believe it was near the trans.
good luck
Old Sep 1, 2006 | 02:08 PM
Perfectionist's Avatar
Some good advice given abaove. Grounding for the gauge is important, and so is an engine running at the designed temperature. Never just remove the T-stat to "fix" a high temp condition,
BigBurch422
Jan 4, 2012 12:00 PM
meanshyguy
Aug 24, 2008 07:50 AM
themex77
24
Aug 24, 2006 12:42 PM
Da1spaz247
Oct 12, 2005 02:33 PM
mattmw88
Oct 19, 2004 09:36 AM
