HELP!! with Brakes
Old Aug 31, 2006 | 06:20 AM
civ-tech's Avatar
Default HELP!! with Brakes
yo
i've done a rear brake conversion on my 94 civic dx an put vti brakes all round on, but the hand brake doesn't work on the left capiler an its not braking properly on the rear right caipler. i bought a new handbrake cable for the left side thinkin it would fix the handbrake but it's still fucko'd. i don't ave a clue why its not braking properly on the rear right caliper. anyone have any ideas (do you need the master cylinder from a vti?) need it sorted
Old Aug 31, 2006 | 07:35 AM
G2 Speed's Avatar
Default Re: HELP!! with Brakes (civ-tech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civ-tech &raquo;</TD></TR><TR><TD CLASS="quote">yo
parking brake is a cable, it uses no fluid so master cylinder wouldn't do anything
isnt' there a spring at the acctual parking brake handle, you can use to tighten..
Old Aug 31, 2006 | 07:42 AM
philosofy1's Avatar
take the console off around the e-brake handle. there you will see the 2 cables connected to the handle, grab a 12mm socket and adjust them.
john666's Avatar
check if the cable is sticking someplace, then check around the caliper where the cable connects to the caliper and also check the caliper.. if u dont see the problem call for back up. also as said before on the handbrake handle one the armrest is remove you will see a i believe it was a 10-12mm nut that you can loosen or tighten,,
Old Aug 31, 2006 | 08:46 AM
civ-tech's Avatar
yo
i tried tightening the handbrake with the 12mm it aint working though. i think it might b getting caught somewere if not do you think it would be the caliper itself?
cheers
Old Aug 31, 2006 | 10:54 AM
G2 Speed's Avatar
cheers</TD></TR></TABLE>
, it's a pretty simple process pull up handle, pulls on cables, calipers squeeze the pads..
so yea I would have to say it's the caliper
Ek9andyroo
Sep 9, 2009 12:42 AM
EKSedAndy
Apr 30, 2008 04:37 PM
Bond
Oct 2, 2005 02:05 PM
lastlude2k1se
10
Jan 17, 2003 12:19 PM
AllShwNoGo
Mar 6, 2002 08:57 PM
