d16a6 mini me swap using y8 head
Old Aug 31, 2006 | 05:47 AM
audiimportech's Avatar
Default d16a6 mini me swap using y8 head
Despite all my effort researching this topic. 95% of mini me discussion and info is geared toward the z6 head swap or a y8 swap using a y7 block. my engine is the d16a6 and I need information on what the compression ratio might be with the y8 head swap. Whether i would need the y8 intake manifold or could use the a6. What timing belt, dizzy, and other obd0 or obd1 problems i might have and also tapping into the block for the oil line to the vtec solenoid. Any help would be appreciated. I would also like to boost in the future and was wondering how i could most effectively keep the CR down without too much cost involved.
Old Sep 1, 2006 | 04:55 AM
Default Re: d16a6 mini me swap using y8 head (audiimportech)
anyone?
Old Sep 1, 2006 | 12:12 PM
bump
Old Sep 2, 2006 | 07:01 AM
no one knows??
Old Sep 3, 2006 | 05:19 PM
Bense's Avatar
http://zealautowerks.com/dseries.html for compression info.
use a y8 headgasket, it's cheap. you can use your a6 dizzy on the y8 head as well. just follow the same procedures as the other guys and use the z6/y8 timing belt.
Ef4doorwagon
11
Mar 8, 2014 11:42 PM
superhatchbackbros
Sep 30, 2010 05:59 AM
94dxt
Nov 3, 2009 02:02 PM
xwhitchx
Mar 23, 2009 01:59 PM
BlackFrog
Aug 29, 2003 03:23 PM
