Q: high pitch sound coming from my motor? what is it?
recently swaped my JDM LS b18B got from Hmotors. put my old turbo set up on it. got it dyno'd hit 212.whp @6psi tuned on chrome. well im hearing this high pitched sound coming from my motor.. sounds like what u hear in ur ear sometimes when u hear ringing in it.. iono how to really explain.. is it electrical or motor wise? iono but im 100% sure i am hearing it and am not trippin.. i havnt really taken my motor to anyone to listen to yet. but wondering if anyone on here knows wwhat it can be or if its anything to worry about. other then taht my motor is runnin good and strong. mysetup is a t3/t4 turbo /w 550cc injecs etc etc
belts and bearings make high pitched squeels, check the belts to see if they are cracked, and look at the pullys to make sure they are running true (straight)
Also, check the wheel bearings
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EK_Fanatic »</TD></TR><TR><TD CLASS="quote">belts and bearings make high pitched squeels, check the belts to see if they are cracked, and look at the pullys to make sure they are running true (straight)
Also, check the wheel bearings</TD></TR></TABLE>
wheel bearings? how do u check that? this high pitch noise is more like a ringing in the ear noise.. belts and cranks pullys do taht kidna noise?? no waay..
i heard the ringing in my ear noise again.. dont u guys know how it sounds lke, fcckin a its hard to explain.. that noise u get in your ear when u start hearing a ringing.. the Eeeeeeeeeeeeeee sound. thast what my motor is making sort of...
hahahah dude, i thought i was the only one wit this problem... mines making that whining high pitch noise too... like, as u gain into the mid rpm range, thats when it kicks in right? homies are telling me its something in the head, so i'm gonna swap mine and maybe go ls-v... but yeah, idk how to fix it nor do i know what it is, but i do have the same problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dee A Nine »</TD></TR><TR><TD CLASS="quote">hahahah dude, i thought i was the only one wit this problem... mines making that whining high pitch noise too... like, as u gain into the mid rpm range, thats when it kicks in right? homies are telling me its something in the head, so i'm gonna swap mine and maybe go ls-v... but yeah, idk how to fix it nor do i know what it is, but i do have the same problem</TD></TR></TABLE>
well mines kinda diff. i only hear it in engine bay after my motor is warmed up. i ant hear it inside the car. it might be an electrical noise? maybe grease got onto my altenator and making wierd noise?? thats only thing i can think of?
jack up the front end, take the wheel off, and spin the hub, if you hear it dragging, or grinding, replace it.
(just in case you dont know what the hub is, its the disc with the studs in it. The brake disc is infront of it. If you dont understand that, take it to a mechanic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EK_Fanatic »</TD></TR><TR><TD CLASS="quote">jack up the front end, take the wheel off, and spin the hub, if you hear it dragging, or grinding, replace it.
(just in case you dont know what the hub is, its the disc with the studs in it. The brake disc is infront of it. If you dont understand that, take it to a mechanic)</TD></TR></TABLE>
i know what the hub is.. but what does this have to do with the car hearing a loud high pitch noise when the car is STILL. idle. parked. ETC.
check belts for stress marks first might even be the alternator ....if not listen and give us a general idea of where its coming from
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teefunk01 »</TD></TR><TR><TD CLASS="quote">check belts for stress marks first might even be the alternator ....if not listen and give us a general idea of where its coming from</TD></TR></TABLE>
yeah noise is coming from my belts. motors coming from japan over age and envrionemtn makes belt go bad. this a 92-93 LS motor.. thats over 13 years of wear on the belts. thanks for da help. i got nothing to worry about then.
B18 CYA
19
Sep 14, 2006 11:59 AM
hybridpatient95
May 8, 2005 11:18 AM
pane93civhb
15
Jan 8, 2005 12:11 PM
