compression test questions....
Old Apr 27, 2002 | 04:15 PM
Monty's Avatar
Default compression test questions....
how accurate are they on a motor that is out of the car? Would a dented oil pan / pick up skew results?
Im thinking you cant really get a good compression on a motor that has been sitting for god knows how long, but I may be wrong.
Total newbie at this so any information is greatly appreciated.
Monty
Old Apr 27, 2002 | 05:23 PM
rainforest's Avatar
Default Re: compression test questions.... (Monty)
ok if it has bad compression it has bad compression.
Old Apr 28, 2002 | 02:43 AM
MikeSarr_GSR's Avatar
Default Re: compression test questions.... (rainforest)
get the engine to normal op temp, remove the sparks, install the compression tester in #1, crank the engine by hand with the motor off 6 revolutions. If it is kind Repeat in each cyl. A healthy engine will get up to comp. Quickly, slow numbers come from bad valves, rod bearings or piston rings. Check with a tech as to his opinions once you get your readings.
[Modified by MikeSarr_GSR, 11:43 AM 4/28/2002]
Old Apr 28, 2002 | 07:13 AM
Chiovnidca's Avatar
Default Re: compression test questions.... (MikeSarr_GSR)
Rod bearings?????????? How can rod bearings cause low compresion readings?
Old Apr 28, 2002 | 09:49 AM
Chubz's Avatar
Default Re: compression test questions.... (Chiovnidca)
I crank until the needle stops moving
Old Apr 28, 2002 | 09:58 AM
earl's Avatar
Proper comp. test should be done with the eng. warm. Since it's out of the car, you can't do that. BUT if the numbers are within 10% of each other doing it cold, you have a good chance. A dented pan (and maybe the oil pick-up, also), must be repaired before installing the engine. It can easily pinch off most of the oil to your engine if u run it that way.
InLimbo87
Nov 4, 2004 05:05 PM
builtprelude
Jan 22, 2004 10:49 PM
RacerXI
Mar 29, 2003 12:11 AM
Andrew 825SM
Oct 19, 2002 10:05 PM
