Windshield wipers?
Windshield wipers?
When i use my windshield washer fluid to clean my windshield ,isnt it suppose pull for the fluid then sway back and forth?mine i pull back on it and just fluid just comes out no swaying after that?let me know if this is correct with a 94 civ lx.
Re: Windshield wipers? (wolferine358)
i have a 94 Dx .. i pull to spray .. and the wiper never came on ...i useually pull down to activate the wiper ... (so i pull forward and then down )
Re: Windshield wipers? (HCJDM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HCJDM1 »</TD></TR><TR><TD CLASS="quote">i have a 94 Dx .. i pull to spray .. and the wiper never came on ...i useually pull down to activate the wiper ... (so i pull forward and then down )
yep me too on my 95 del Sol
I'll try this again,
This may seem like a strange question, but does everything work fine when the headlights are on?
If it does it is not your motor, fuse, balah blah blah, it is a disconnection in your wiring.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wolferine358 »</TD></TR><TR><TD CLASS="quote">wow so im not the only one wit this tiny prob.</TD></TR></TABLE>
i really dont think its a problem ... i remember my dads 92 Accord ...brand new did the same thing ... i thik that just how its designed ...
do the wipers work at all ?
or maybe you can combine the two at the same time .. pull down and twardts you at the same time and maybe the spray and the wipers will go at the same time ...
but anyways i that how the wipers and spray were ment to opperate ...
Re: (florida)
why would you associate the headlights with the wiper speeds or motor? they work off of 2 different stalks, and even if they did work on the same one you cant cancel out the motor if everything else works fine.. bad information to you sir
Maybe on your EG. But on an EK, they are connected. The service manual (Haynes) say to check the wiring connections if the problem stated at the beginning of this thread occurs.
You should try being nicer to people.
D16Z6racing
03-25-2012 09:20 AM
