H23 Vtec
I started a h23vtec build last fall and the machine shop should be done this week. From what I have read you shold only rev the engine to around 7000. If the machine shop balnced the crank rods pistons and flywheel up to 10,000rpms is it just the R/S ration that prevents me from going to 8000? The only reason I'm asking is because I have skunk2 cams and would like to rev higher to see the cams make better power.
I know this doesn't make a diff. but I have new bearings, and would be willing to replace them once or twice a year to be able to rev higher.
Which block is it, an H23a1 or the JDM H23A?
The JDM version has a redline of 7200 rpm & has larger mains so I'm comfortable reving mine to around 7500 rpm which is where the power is already falling off anyways even with stage 3 cams.
The US version has a redline of ? (6300 rpm thereabouts) with smaller mains. I wouldn't suggest reving it over 7000 rpm's, though I know of guy that his to 8000 rpm regularly. Not very good for longevity because it puts on lot of stress on the cylinder walls because of the lower R/S ratio.
get it dyno'd, see where the power falls off and no need to rev it higher then that...should be fine....i put 9,000 miles on my h23/vtec and the block had orgionally 227,000 and ended up with 236,000 with no issues revving it to 7200 daily on a bone stock bottom end.....prob didnt make much power past 7000, so dont go crazy wirh revving this this, it will only be harming your motor...
I was surprised to find that the H23A vtec, which has a redline of 7200 RPM, does not originally come with oil squirters. I think an NA street car would be fine without squirters since it won't see the high RPM's often or for long periods. A boosted, or track car could make use of them to cool the OEM pistons.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SB tuning »</TD></TR><TR><TD CLASS="quote">get it dyno'd, see where the power falls off and no need to rev it higher then that...should be fine....i put 9,000 miles on my h23/vtec and the block had orgionally 227,000 and ended up with 236,000 with no issues revving it to 7200 daily on a bone stock bottom end.....prob didnt make much power past 7000, so dont go crazy wirh revving this this, it will only be harming your motor...</TD></TR></TABLE>
That sounds like the best way. I may of been thinking of 6200rpms was the sug. redline. What header did you run?
I have a h22 block with a JDM F22 DOHC crank, crower rods(over kill), new crank and main bearings, and type s pistons. So the set up should be pretty fresh. I plan on putting the oil squirters in, you just have to bend them for clearance. I'm not sure on this but i read that they are not really needed for the setup. Just for a little extra safty.
Power Rev Racing
Sep 9, 2004 04:00 PM
