abs elimination
I'm taking out the abs from my car and am trying to figure out what parts i need.
I know i need a new master cylinder, proportioning valve, and brakelines.
for the proportioning valve can anything other than the rs one be used? maybe from the si?
and if someone could tell me exactly what brake lines i need from the rs that would be great. unless there is a better alternative to using the oem lines.
Don't mix the master cylinder and the brakebooster. it will cause the brakes to lock up. If you have a non-abs master cylinder then you have to get a non-abs brakebooster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2 Mang »</TD></TR><TR><TD CLASS="quote">you can use the prop valve from any civic EG without ABS, and you need the front brakelines from them too</TD></TR></TABLE>
doesnt the fact that they use rear drums instead of discs affect that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superls92 »</TD></TR><TR><TD CLASS="quote">Don't mix the master cylinder and the brakebooster. it will cause the brakes to lock up. If you have a non-abs master cylinder then you have to get a non-abs brakebooster.</TD></TR></TABLE>
thanks, didnt know that. I was about to buy a master cylinder, but i guess now i should be on the lookout for the both toghether.
i just did my abs delete. get the 4 front lines for the rs, the rs master cylinder and booster and the rs proportioning valve and it all bolts up and is done in about 3 hours (the average time taken from what i've see)
some one just told me that you can use the rs master cylinder with an abs booster, can anyone comfirm that you cannot?
and does the booster have to be from an rs or can that also be from an si?
and when using the si prop vavle does that change the placement of any of the lines?
