VTEC Common Problem
Is there any common problems that integras have when VTEC engage?
My check engine light went on when i engaged in vtec today. Going to check out the codes later but just wondering.
Just jump you Diagnostic port with a paper clip, and watch the CEL light..
Long flash = first # in the CEL code
Short flast = Second # in CEL code
Just like if it flashed like this:
long..long..short..short.. = Code 22
Thats how it reads, if you didn't know it already.. And that's probably the code you threw, which is VTEC Sileniod Malfuntion/System Malfunction. On a scanner it would probably be code P1259.. Just my guess?
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00sted_hatch »</TD></TR><TR><TD CLASS="quote">Just jump you Diagnostic port with a paper clip, and watch the CEL light..
it could be a lot of things though.... I get my knock sensor code when i hit vtec because my knock sensor isn't wired yet....
just do what he said and check the code yourself. autozone sucks.
and then you will know what the problem is
</TD></TR></TABLE>it could be a lot of things though.... I get my knock sensor code when i hit vtec because my knock sensor isn't wired yet....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by God.Loves.Ugly »</TD></TR><TR><TD CLASS="quote">
it could be a lot of things though.... autozone sucks.
Two VERY good points..
integracivic94
Aug 22, 2004 08:42 AM
AngryNerdRock
Aug 23, 2003 06:13 AM
