No 12v power to injectors..
Old Aug 26, 2006 | 05:11 PM
FastAsleep's Avatar
Default No 12v power to injectors..
obd0 B16 in a 91 EF.
motor isn't getting proper fuel
I am not getting 12v power to the injectors.
checked out the injectors themselves, they checked out ok all 2.5 ohms
checked the resistor box, thats fine.
checked the main relay, thats ok
i have 41psi fuel pressure
suggestions?
Old Aug 27, 2006 | 07:12 AM
FastAsleep's Avatar
Default Re: No 12v power to injectors.. (FastAsleep)
bump for help..
Old Aug 27, 2006 | 07:42 AM
saikouEF8's Avatar
check for loose thermostat ground
Old Aug 27, 2006 | 07:50 AM
FastAsleep's Avatar
Default Re: No 12v power to injectors.. (saikouEF8)
checked it, cleaned the crap out of it.. reconnected. no change. thanks for the input though
Old Aug 27, 2006 | 07:53 AM
saikouEF8's Avatar
pehaps u have a bad injector relay. do u hear the pump? if so, then i suspect its the injctor relay. no injector but everything else working kinda means the relay isnt working.
Old Aug 27, 2006 | 08:00 AM
FastAsleep's Avatar
i wasn't aware of an injector relay... ? i have checked the main relay, the injector resistor, the injectors themselves... the fuel pump does turn on and i have 41psi pressure.
Old Aug 27, 2006 | 08:13 AM
saikouEF8's Avatar
im not sure where to proceed... ill go take a look at my car to see if i forgot anything...have u tried reseting your ecu?
Old Aug 27, 2006 | 08:38 AM
FastAsleep's Avatar
yes i have reset the ecu multiple times through this. The ecu isn't picking up any cells. i can throw a cell by disconnecting a sensor though so i am preetty sure its working ok...
Old Aug 27, 2006 | 08:57 AM
4dOoR-Ex's Avatar
ok last time i checkT obd0 injecters wer powerd by 5.5v so if getting anything lower then that replace your injector resister box..because obd1/obd2 injecters require 12v.....about the 41psi dosent sound rite do u have a fuel preasure regulater? if i was you i wound bring it down to around 30 see if it starts
Old Aug 27, 2006 | 09:01 AM
FastAsleep's Avatar
Default Re: (4dOoR-Ex)
the resistor box checks out. and 41 psi is within spec also.
Old Aug 27, 2006 | 09:04 AM
4dOoR-Ex's Avatar
hit me up on aim lilsn0py
Old Aug 27, 2006 | 09:23 AM
FastAsleep's Avatar
ok.............
Old Aug 27, 2006 | 06:13 PM
type Gendy's Avatar
Default Re: (FastAsleep)
fuel filter?
Old Aug 27, 2006 | 06:15 PM
FastAsleep's Avatar
Default Re: (type Gendy)
fuel filter is brand new. and the problem existed b4 i replaced it.
Old Aug 27, 2006 | 06:25 PM
type Gendy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4dOoR-Ex &raquo;</TD></TR><TR><TD CLASS="quote">ok last time i checkT obd0 injecters wer powerd by 5.5v so if getting anything lower then that replace your injector resister box..because obd1/obd2 injecters require 12v.....about the 41psi dosent sound rite do u have a fuel preasure regulater? if i was you i wound bring it down to around 30 see if it starts</TD></TR></TABLE>
wrong!
Voltage between the red/black terminals and a body ground on each injector should read battery voltage.
Fuel pressure at the fuel filter should be between 35-41 psi with the vacuum hose of the fpr disconnected.
Old Aug 28, 2006 | 06:04 AM
crx_88_si's Avatar
check your thermostat ground.
Old Aug 28, 2006 | 11:26 AM
Perfectionist's Avatar
Do you have any voltage at the injector clips themselves? If not, the path is basically... a fuse, ignition switch, main relay, resistors, injector coils, then to ground through the ECU, pluss all the wire and connectors in between.
Old Aug 28, 2006 | 04:40 PM
FastAsleep's Avatar
Default Re: No 12v power to injectors.. (Perfectionist)
yeah i seem to remeber following it back to the #2 fuse not having any power . then i checked the wires off the ignition switch and one that is supposed to have continuity didn't
Car fan
Sep 27, 2016 10:58 AM
charlie_sohc
Oct 13, 2010 05:07 PM
90dxb20
Oct 18, 2007 08:29 PM
Btothe3rdDegree
16
Nov 28, 2004 06:50 AM
EGHatchy
Jul 14, 2002 11:25 AM
