Help with Uberdata and Walbro 255
Old Aug 26, 2006 | 10:19 AM
motormike40's Avatar
Default Help with Uberdata and Walbro 255
Hey, I need help trying to tune uberdata with my turbo setup. Im using a b18b1 with a t3 turbo, 450cc injectors, and a Walbro 255 fuel pump. I had it running well before I installed the pump, but once I installed it, it dumps too much gas into the engine. What do I change to make the pump work?
Old Aug 26, 2006 | 01:48 PM
Enzo Speed's Avatar
Default Re: Help with Uberdata and Walbro 255 (motormike40)
Maybe the pump raised your base fuel pressure. Get an adjustable FPR and lower it.
Old Aug 26, 2006 | 01:51 PM
Enzo Speed's Avatar
Default Re: Help with Uberdata and Walbro 255 (Enzo Speed)
Actually, if you don't have a FPR, you can use a gauge to see what your new base pressure is. Then change it accordingly in Uberdata. There is a place to input the fuel pressure in uber. I think it's set to 42psi by default.
turbolsvtecej1
Sep 7, 2014 04:06 PM
boosted.si04
Dec 7, 2011 11:32 AM
CFDOHCVTECEG
Feb 2, 2007 03:32 PM
B16CRXT
Aug 29, 2004 11:06 PM
JASON77
Aug 14, 2004 01:53 PM
