what sensor is this? do i need to put it on my ls/vtec
Old Aug 26, 2006 | 04:24 AM
si0385.'s Avatar
Default what sensor is this? do i need to put it on my ls/vtec
1992 cx its on the back right side of the intake manifold... is this an emimssions sensor will the car run normail w/o it... if not that would be perfect because its the same kinda plug i need for my vtec pressure switch
Old Aug 26, 2006 | 04:57 AM
si0385.'s Avatar
bump someones gota have a helms or a hanes they can help me with
Old Aug 26, 2006 | 05:15 AM
si0385.'s Avatar
Default Re: (si0385.)
ttt
Old Aug 26, 2006 | 05:20 AM
gotone4ya's Avatar
the small outlet goes to your charcoal cannister. if you start your car, then cover the small hole with your finger, you will notice the idle change.
i didnt hook mine back up when i swapped my z6 into an old crx, and it ran ok.
Old Aug 26, 2006 | 08:34 AM
instrument's Avatar
purge control solenoid valve.
Old Aug 26, 2006 | 09:01 AM
raiden571's Avatar
i had it on my z6, when i went lsvtec, i either didnt have it, or didnt use it. either way, the car runs fine, and my idle is fairly steady even with 1000cc injectors.
Old Aug 26, 2006 | 11:25 AM
happyabortion's Avatar
Default Re: (raiden571)
yea itll run fine if you dont have it or not but if you cover the little vaccum hose and you think your car idles better then just cover up the vaccum line
Old Aug 26, 2006 | 01:32 PM
EvilPhu's Avatar
Default Re: (happyabortion)
evap purge soleniod, theres two tube that come out of the evap canister. one goes here and the other goes the the throttle body. It's for emission use, but you have a ls/vtes in there so i guess you wouldn't care about emission inspection.
Gattlin
27
Jul 20, 2018 10:28 PM
almostjdmeg
Jan 31, 2010 05:43 PM
93 lude
Apr 4, 2009 05:03 PM
jdm_integra96
Dec 22, 2008 06:35 PM
Takumi Fujiwara
Mar 24, 2005 08:11 PM
