Replaced thermostat...Temp gauge still not warming up...
Old Aug 25, 2006 | 03:24 PM
P@@RB@Y's Avatar
Default Replaced thermostat...Temp gauge still not warming up...
I replaced the thermostat in my GSR and the gauge came up a bit more than before but still not getting to temp.Need some help with this one.Ive been driving for a couple months with the temp gauge not setting properly and it got worse and worse, until it wouldnt get to temp at all.
Could it not get to reg. temp. if my radiator cap is bad?
What activates the fan switch the temp gauge or the actuall temp of the engine?
What else could it be?
Thanks
Old Aug 25, 2006 | 03:39 PM
P@@RB@Y's Avatar
Default Re: Replaced thermostat...Temp gauge still not warming up... (P@@RB@Y)
tech tech tech
Old Aug 25, 2006 | 03:55 PM
P@@RB@Y's Avatar
Old Aug 25, 2006 | 07:55 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
did u make sure it was hooked up to the sensor on the side of the head under the distributer
Old Aug 26, 2006 | 11:13 AM
92civeg's Avatar
Default Re: Replaced thermostat...Temp gauge still not warming up... (street dreams)
coolant temp sensor......test it or just replace it there cheap enough
Old Aug 26, 2006 | 01:39 PM
THEUSED's Avatar
Default Re: Replaced thermostat...Temp gauge still not warming up... (92civeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street dreams &raquo;</TD></TR><TR><TD CLASS="quote">did u make sure it was hooked up to the sensor on the side of the head under the distributer</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civeg &raquo;</TD></TR><TR><TD CLASS="quote">coolant temp sensor......test it or just replace it there cheap enough</TD></TR></TABLE>
FYI there are two both under the Distributor, one is for the ECU its the 2 wire one, the wire one is what your coolant gauge runs off of.
Old Aug 26, 2006 | 04:36 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P@@RB@Y &raquo;</TD></TR><TR><TD CLASS="quote">Could it not get to reg. temp. if my radiator cap is bad?</TD></TR></TABLE>NO, the radiator cap won't prevent it from getting hot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P@@RB@Y &raquo;</TD></TR><TR><TD CLASS="quote">What activates the fan switch the temp gauge or the actuall temp of the engine?</TD></TR></TABLE>There's 3 temperature 'sensors' & they don't share information between them.
Fan switch is in the thermostat housing, with a 2-wire plug.
Coolant temperature sensor for the ECU is in the head, with a 2-wire plug.
Coolant temperature sender for the gauge is nearby in the head, with 1 wire.
Since it's a GSR, there's also a VTEC oil pressure sensor at the VTEC spool valve, it's got a 2-wire plug similar to the ECU's temperature sensor. But this plug is green plastic.
Your gauge might be bad, or the circuit between sender & gauge might be bad (loose/dirty/corroded?)
Old Aug 26, 2006 | 04:50 PM
CDtegGo's Avatar
if you ground out the temp sensor wire the gauge should go all the way to the top. If that happens you can rule out the gauge.
Old Aug 27, 2006 | 01:28 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Replaced thermostat...Temp gauge still not warming up... (CDteggy)
My temp gauge in my cluster recently stopped working right. I thought it was the cluster, since im still getting a temp reading in CromePRO when datalogging. Thanks for the knowledge.
Old Aug 27, 2006 | 04:36 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CDteggy &raquo;</TD></TR><TR><TD CLASS="quote">if you ground out the temp sensor wire the gauge should go all the way to the top. If that happens you can rule out the gauge.
</TD></TR></TABLE>Gotta be careful... Take the wire OFF of ground before the gauge pegs all the way up. The Helm book has a warning about that (might fry the gauge?)
TshingY
Jan 25, 2010 12:59 PM
stocker2shocker91
Mar 24, 2008 01:19 PM
CA6VTEC
Dec 29, 2005 01:13 PM
svtec
Jan 24, 2005 05:43 AM
erniecars
Jun 14, 2002 11:48 PM
