Having idling problem! NEED HELP!!!
Old Aug 24, 2006 | 11:30 AM
redrota24's Avatar
Default Having idling problem! NEED HELP!!!
i just did a b16a (obd1) swap in a 97 civic cx (obd2a), used b16 ecu and boomslang conversion harness (obd2a-obd1) with cx engine harness, pinned vtec, the car will not idle unless warmed up with IAC unpluged. changed IACV with known good one. idling problems continues. moved pins on ecu from a14-a12. checked injector wiring. checked timing multiple times and its perfect.
Old Aug 24, 2006 | 02:07 PM
bpwrdeg's Avatar
Default Re: Having idling problem! NEED HELP!!! (redrota24)
I put a DX mannifold on my CX motor and it was doing the same rought idle problem, so i changed the TPS, Map sensor and cleaned the IACV and it works perfectly now...not sure if it will work but its worth a try
Old Aug 24, 2006 | 02:13 PM
defkid999's Avatar
check your cold start valve....that might be the problem...it was when i had my gsr swapped ek
JDM kid
Jan 15, 2013 09:30 AM
cheehee
Oct 21, 2005 06:02 PM
msmithgsr2131
Mar 27, 2005 10:03 AM
s0ulless
Nov 4, 2004 07:03 AM
b18c5eg
Dec 29, 2002 05:49 PM
