transmission squeal when down shifting
Old Aug 23, 2006 | 02:36 PM
94JDMcivic's Avatar
Default transmission squeal when down shifting
I have a 1994 Civic Ex 5-speed. When I'm in 1st and shift to 2nd, at around 5,000 rpms, when you push the clutch in it makes a loud squeal like a belt squeal. When you down shift from 3rd to 2nd at around 5,000 rpms it also squeals. Also when I first crank the car and put it into reverse, it grinds going into reverse. Does any one know what might be the problem? Please help! Thanks.
Old Aug 23, 2006 | 03:29 PM
Bense's Avatar
Default Re: transmission squeal when down shifting (94JDMcivic)
grinding while going into reverse is normal. press the clutch in and shift from 1-2-R to prevent the grind.
sounds like it might be a pilot bearing, but your describtion is a bit unclear.
Old Aug 23, 2006 | 03:34 PM
Formula's Avatar
The syncro for 2nd gear could be going bad.
Old Aug 23, 2006 | 03:36 PM
Bense's Avatar
Default Re: (Formula94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Formula94 &raquo;</TD></TR><TR><TD CLASS="quote">The syncro for 2nd gear could be going bad. </TD></TR></TABLE>
it could be, but the gears would grind instead of squeal.
Old Aug 23, 2006 | 04:06 PM
fizeks's Avatar
Default Re: (Bense)
check your tranny mount... it could be its broken.. causing it to squeal when u downshift at those rpm cuz the motor shifts its wieght... it happend to me just check it out..if not just take bense's advice he knows his stuff
Old Aug 23, 2006 | 04:19 PM
B16CRXT's Avatar
Throw out bearing could be going out. Only way to know for sure is to remove the tranny and check out the visible bearings.
Old Aug 23, 2006 | 04:35 PM
Bense's Avatar
Default Re: (B16CRXT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16CRXT &raquo;</TD></TR><TR><TD CLASS="quote">Throw out bearing could be going out. Only way to know for sure is to remove the tranny and check out the visible bearings.</TD></TR></TABLE>
yep, pretty much.
5 hours if taking the trans apart to see whats up &gt; two weeks of trying to figure out wtf is going on
NOOdS
Apr 20, 2009 11:04 AM
DC5_lov3r
Dec 10, 2007 05:51 PM
SLO Sol
14
Nov 12, 2005 04:59 AM
JDMflavor_EJ
Jul 12, 2004 09:07 PM
91hatchcivic
Jun 18, 2003 03:11 PM
