help with oil
Old Aug 23, 2006 | 11:23 AM
Hiroshima_VTi-S's Avatar
Default help with oil
on my dip stick there's 2 dots (holes) for measurement, well my oil is 1/4 of an inch higher over the top hole. can too much oil be bad? [my car burns oil] so i kinda over filled it accidently...
Old Aug 23, 2006 | 11:45 AM
philosofy1's Avatar
Default Re: help with oil (Hiroshima_VTi-S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hiroshima_VTi-S &raquo;</TD></TR><TR><TD CLASS="quote">on my dip stick there's 2 dots (holes) for measurement, well my oil is 1/4 of an inch higher over the top hole. can too much oil be bad? [my car burns oil] so i kinda over filled it accidently... </TD></TR></TABLE>
if it burns oil, it's already a bad thing. either you have a bad gasket or rings. but since your going to burn it up, i wouldn't worry about it.
Old Aug 23, 2006 | 11:59 AM
HXvtec's Avatar
dam your lucky i dont have any oil on my dipstick. if you over fill it a little it wont kill it. if you start smoking out the exhaust, then theres a problem.
Old Aug 23, 2006 | 12:12 PM
Syndacate's Avatar
It shouldn't be in there...as long as it's not like, twice the length of the fill mark you should be pretty fine. Though you're burning it so it'll go down.
BTW: How did you check it, ice cold engine on flat ground I hope?
97grnrs
Nov 21, 2006 10:35 AM
fackyou
Oct 4, 2006 03:45 PM
kegard
32
May 30, 2005 12:12 AM
Jer'rome
Mar 6, 2004 11:25 AM
d9h
Jan 31, 2004 11:58 PM
