gsr delsol CEL???
Old Aug 23, 2006 | 10:39 AM
midnitesol's Avatar
Default gsr delsol CEL???
CEL came on about a week ago i read threads and they mention a little gray plug by the ecu to check. i have a 95 del sol vtec and there is only a blue plug with a green cover on it. am i looking in the wrong spot? please help!
Old Aug 23, 2006 | 10:45 AM
Stoich EG2's Avatar
Default Re: gsr delsol CEL??? (midnitesol)
that would be it. It has two wire going to it, correct? now jump those two wires (connect them with a paper clip or something). Turn your car to the "ON" position (do not start the car) and check the blinks of the CEL
for poor man's R basically what i have
Old Aug 23, 2006 | 11:03 AM
midnitesol's Avatar
Default Re: gsr delsol CEL??? (ADVAN EG2)
it actually has 5 wires running to it so let me take a pic and ill post it shortly
(yeah can't wait for the poorman's!)
Old Aug 23, 2006 | 11:21 AM
Stoich EG2's Avatar
well, the plug with 2 wires should be in their with the green cover over it too
Old Aug 23, 2006 | 11:25 AM
EGwhat!!!'s Avatar
Here is a how to video for checking CEL Right Click Save As
here is a pic of the Jumper to check the codes
SEARCH
Old Aug 24, 2006 | 03:18 PM
midnitesol's Avatar
Default Re: gsr delsol CEL??? (EGwhat!!!)
alright looked for gray plug and cant find it. this is what i got:
http://myspace-762.vo.llnwd.ne...m.jpg
any input please!
Old Aug 24, 2006 | 03:21 PM
EGwhat!!!'s Avatar
it the one on the left in the pic take it out of the green thing
Old Aug 24, 2006 | 03:29 PM
midnitesol's Avatar
sweet thanks. how did u get the pic to pop up?
Old Aug 24, 2006 | 03:30 PM
EGwhat!!!'s Avatar
just put this http://myspace-762.vo.llnwd.ne...m.jpg in between these [IMG][/IMG]
Old Aug 24, 2006 | 03:36 PM
midnitesol's Avatar
oh yeah forgot that. alright now i know a long blink is 10 short is 1 but does it continue throwing the same code over and over? it goes short, long, short, long, etc.
Old Aug 24, 2006 | 09:02 PM
the soL that could's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by midnitesol &raquo;</TD></TR><TR><TD CLASS="quote">oh yeah forgot that. alright now i know a long blink is 10 short is 1 but does it continue throwing the same code over and over? it goes short, long, short, long, etc.</TD></TR></TABLE>
it will throw the same code over & over until you fix it. if you have more than 1 problem, it will display only 1 of them at a time until you fix it... then another 1 will pop up once it's taken care of.
Old Aug 25, 2006 | 10:25 AM
midnitesol's Avatar
Default Re: gsr delsol CEL??? (the soL that could)
ok it throws a short one then a long one am i reading it wrong cuz i believe a code 11 doesnt exist! please help!
Old Aug 25, 2006 | 10:29 AM
EGwhat!!!'s Avatar
your throwing codes 1 and 10
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 Exhaust Gas Recirculation insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Fuel Tank Pressure Sensor low input
92 Evaporative Emission Control System insufficient purge flow
Old Aug 25, 2006 | 11:12 AM
midnitesol's Avatar
cool thanx. do u know how to fix the IAT sensor?
Old Aug 25, 2006 | 11:18 AM
EGwhat!!!'s Avatar
replace it
Old Aug 25, 2006 | 04:55 PM
midnitesol's Avatar
cool thanks for all your help.
rhoades
10
Dec 28, 2009 12:42 AM
JDMReverend
Sep 18, 2008 04:47 AM
Powered By Garrett
10
Feb 16, 2007 05:46 PM
JunY
Mar 2, 2006 05:52 PM
Jonathan_ED3
Apr 23, 2003 08:08 PM
