Problem....3rd Cat in 4 months.
From: You can be my wingman anytime...., Las Vegas, US
In the past 4 months i have gone throgh 2 catalytic converters, and are on my 3rd. I have a b18b, with intake header and exhaust. The guy at the muffler shop said he pulled out a large ball of catalyst, when i got the new one put on....Anybody knwo why this is happening???
Thanks...will
Thanks...will
Yea, those are the only engine mods I have, and I am using all stock fuel and igniton settings. And I dont change my oil, so......It should be ok.
Yup, sounds like a fuel problem. More then likely you are running rich.......happen to me too. MY 02 sensor went bad, causing the car to run rich.............
definatly agree with the above. Check a/f and plugs. Replacing the cat with a test pipe might be a quick fix, but it's not the solution to your problem. When you get the problem sorted out, buy a nice Carsound or Random Tech cat to replace it with.... might as well get a high flow if you're gonna get another. good luckl
-erik
-erik
Canuk_SiR
Jun 8, 2003 07:47 AM
