Idling with P13 ecu
Old Aug 22, 2006 | 12:03 AM
k_lude's Avatar
Default Idling with P13 ecu
I have a GSR ecu on and it runs fine...but when i changed it to the p13 the car idles....can this be a motor problem?
Old Aug 22, 2006 | 01:02 AM
BlUAc's Avatar
Default Re: Idling with P13 ecu (k_lude)
no disrespect bulldog but can you be more specific as to the problem
Old Aug 22, 2006 | 06:58 AM
k_lude's Avatar
Default Re: Idling with P13 ecu (BlUAc)
yeah...thats kool....see the motors in a hatch....it's been running on a GSR Ecu..yesterday I went to my car a the shop because my other ecu is in there...its an obd1 p13..I changed it with the GSR one but it started to idle alot so can anyone help??
Old Aug 22, 2006 | 07:44 AM
MadCityLude
Guest
Posts: n/a
definition of idle = ??????
All running engines idle. That is not a problem. Do you maybe mean surges or dies or bogs or kills or ???
Old Aug 22, 2006 | 08:14 AM
k_lude's Avatar
Default Re: Idling with P13 ecu (MadCityLude)
idle jumps up and down...sort of boggs..but when the GSR ecu is back in it works fine.
Old Aug 22, 2006 | 02:14 PM
Eddiebx's Avatar
sounds like ur egr valve is possilbly stuck open a bit.
Old Aug 23, 2006 | 01:10 AM
k_lude's Avatar
Default Re: (Eddiebx)
were is the egr valve located???
B18tSOL
Feb 21, 2007 06:07 AM
dank24
24
Jul 28, 2006 02:42 AM
mikeunreal2
21
Apr 13, 2006 06:36 PM
danslerugueux
18
May 15, 2004 01:12 PM
LSpimpTEC
Apr 28, 2003 11:29 PM
