speedometer bouncing around
Old Aug 21, 2006 | 06:16 PM
BigIslandBoi's Avatar
Default speedometer bouncing around
speedometers bouncing all over the place. would changing the VSS fix the problem? or could there be a short somewhere? also will having a bad VSS turn the CEL on?
Old Aug 21, 2006 | 07:30 PM
JDMbull's Avatar
I have the same problem code 17 right
Old Aug 21, 2006 | 08:12 PM
Default Re: (JDMbullshit)
yup
Old Aug 21, 2006 | 08:13 PM
cambopheonix56's Avatar
Default Re: (BigIslandBoi)
17 VSS - speed sensor
Probably is going bad. Replace it.
Old Aug 21, 2006 | 08:49 PM
toekneexD's Avatar
Default Re: (cambopheonix56)
yepp.. speed sensor is going out.
Old Aug 22, 2006 | 02:39 AM
sohc1200cc's Avatar
first, try to clean your vss.. if it doesn't work, then replace it..
Old Aug 22, 2006 | 02:41 AM
92ehatch's Avatar
Default Re: (sohc1200cc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc1200cc &raquo;</TD></TR><TR><TD CLASS="quote">first, try to clean your vss.. if it doesn't work, then replace it..</TD></TR></TABLE>
mine did this, and CLEANING IT HELPED
so before you go and buy a new one or toss yours out clean it.
take it off the tranny (2 12 mm bolts i think)
then take it inside and take that bitch apart.
its gonna have some grease in it, but its gonna be all nasty and sticky.
clean that **** off and regrease it.
then clean the electrical connecters and throw some dielectric grease on them
install and test.
Old Aug 22, 2006 | 02:47 AM
sohc_freak's Avatar
where is it located?
because i face the same problem from time to time!
Old Aug 22, 2006 | 02:50 AM
92ehatch's Avatar
Default Re: (sohc_freak)
on the top of the transmission, has 2 12mm bolts holding it on. and 1 connecter on the top of it.
cant miss it (passenger side)
Old Aug 22, 2006 | 03:27 AM
sohc_freak's Avatar
Default Re: (93cb7sedan)
thnx man
civicSF98
10
Aug 30, 2009 05:10 PM
johnjjy
Jan 14, 2006 02:02 AM
kuruption0722
Nov 17, 2005 11:08 PM
srv3fender
Jun 15, 2004 02:52 PM
miataguy
Jul 17, 2003 02:25 PM
