B16 swap
Old Apr 26, 2002 | 04:08 AM
pewter b16a's Avatar
Default B16 swap
I just swapped my singlecam for a JDM B16 1st gen. For some reason the rpms jump from 1,000 to 2,000 while idleing. Instead of just idleing normally. And it doesnt stop. Has anyone had this problem and can you help me? Its kinda annoying now.
Old Apr 26, 2002 | 04:19 AM
Charlie Moua's Avatar
Default Re: B16 swap (pewter b16a)
what the hell is a JDM B16 singlecam? are you are you have a B series motor?
Old Apr 26, 2002 | 04:22 AM
91sifreak's Avatar
New User
Default Re: B16 swap (Charlie)
I had it doing the same thing, turns out that i had the TPS sensor in the wrong position, just had to loosen the bolt and then move the TPS back and forth then it quit, also on another swap their was a small hole in one of the vacuum lines , replaced and stopped that issue, so try those things.
Old Apr 26, 2002 | 04:26 AM
I swapped my single cam for a japanese B16.
Old Apr 26, 2002 | 04:28 AM
Default Re: B16 swap (91sifreak)
Do I loosen the TPS and move it back and forh while the car is running?
Old Apr 26, 2002 | 04:38 AM
91sifreak's Avatar
New User
Sure i did, when it is going up and down the rpm range. What ou may want to try is tak eit off and make sure when you look at the tps there is a part that will fit right in the TPS housing, it only can fit one way, make sure you get the square thing on the TPS center right in the T/B, then out the screws back in and if still going up and down move it twisting like till the engine settles down, also check the idle position of the bitterfly in the throttlebody, it's the screw in the front of the T/B, just mske sure it not all the way in.
Old Apr 26, 2002 | 05:48 AM
B16CRX's Avatar
I would definately check all the vacuum lines. Thats been the cause of at least half of the idle problems I have seen.
Try playing with the TPS too like 91sifreak said. You could even try changing it with the one from your old engine to see if it changes anything.
Old Apr 26, 2002 | 09:42 AM
pelotudo's Avatar
OT, but 91sifreak, what do you run with your B16a? You going down to Bithlow tonight?
jB
Old Apr 28, 2002 | 05:48 AM
91sifreak's Avatar
New User
Default Re: B16 swap (PeloTudo)
Did moving the TPS around work or messing with the idel control spring on the throttlebody?
Old Apr 28, 2002 | 07:49 AM
Kataku2K3's Avatar
Definately check ur TPS it should be reading 0.5 volts at idle. That's most likely ur problem. Hope it works!
Old Apr 28, 2002 | 09:34 AM
Count Blah's Avatar
From: A place where stupidity runs rampant aka NorCal
Default Re: B16 swap (JDMspecEG6)
Could also be a throttle body leak, check that area for leaks with your finger too.
-Todd
Old Apr 28, 2002 | 12:03 PM
spdster's Avatar
New User
Default Re: B16 swap (Count Blah)
I had a similar problem with my B16...we did the basic TPS and Vacuum leak check...but it turned out to be my throttle cable, as there wasn't enough slack in the line.
[Modified by spdster, 1:03 PM 4/28/2002]
Old Apr 28, 2002 | 02:08 PM
june's Avatar
Default Re: B16 swap (spdster)
I had the same problem. And it was the tps. You have to play with it a bit.
civic889802
May 31, 2006 01:36 PM
kos99ngel
24
Sep 15, 2005 05:02 PM
methos713
May 30, 2003 01:28 AM
mistake_2
May 7, 2003 12:12 PM
