i need help...
Old Aug 21, 2006 | 05:58 AM
ef kyle's Avatar
Default i need help...
i have a jdm b16 with intake high comp pistions and rods...during higher rpms it is jerking...i can not figure out the problem, could it have anything to do with the spark plugs i am using? i am using ngk plugs?
Old Aug 21, 2006 | 06:06 AM
ludesrv's Avatar
Plugs won't cause a 'jerk'. Explain your situation a bit more. Maybe some details on the engine and the car?
Old Aug 21, 2006 | 06:12 AM
ef kyle's Avatar
when i get to like 6500 it will not pull as hard then around 7000 it will start pulling hard again...
Old Aug 21, 2006 | 06:14 AM
ludesrv's Avatar
Elaborate. You said you have high comp pistons? Did you get it tuned? You might be leaning right out which could cause detonation. If that happens, kiss your ringlands goodbye!
Old Aug 21, 2006 | 06:27 AM
ef kyle's Avatar
it has yet to be tuned...if i get it tuned should i switch to obd1?
Old Aug 21, 2006 | 07:03 AM
ludesrv's Avatar
Default Re: (ef kyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef kyle &raquo;</TD></TR><TR><TD CLASS="quote">it has yet to be tuned...if i get it tuned should i switch to obd1?</TD></TR></TABLE>
OBD0 only let's you tune up to 8000rpm, after that it uses the last known fuel map/timing map (the one from 8000rpm) to continue it's journey upwards, won't make maximal power. Using OBD1 let's you go all the way to whatever you want!
Another note, get your **** tuned and you won't have that studder. You are probably leaning out large. Use 94 octane gas if you are untuned and have high comp (over 11.5:1).
Old Aug 21, 2006 | 07:13 AM
ef kyle's Avatar
alright man thanks
Old Aug 21, 2006 | 11:21 AM
B6tizzleHatch's Avatar
if i was running a high compression motor, i would convert to obd1 and run the hondata s200, perfect for all motor cars.... my $.02
MilanoCivic97
Mar 9, 2007 10:12 PM
dohdoh420
Feb 5, 2006 04:34 PM
Monkdann
Oct 26, 2004 12:10 PM
SOHC_MShue
Apr 15, 2004 10:00 AM
ImAcracker
Apr 4, 2004 07:42 PM
