4291-ZFR6F-11 NGK plugs?
Old 04-13-2004, 09:56 AM
SOHC_MShue's Avatar
Default 4291-ZFR6F-11 NGK plugs?
anybody using these plugs on their turbo sohc vtec motor? I was told to get these 1 step colder plugs for my turbo setup on my y8.
Old 04-13-2004, 10:10 AM
mos
mos's Avatar
Default Re: 4291-ZFR6F-11 NGK plugs? (SOHC_MShue)
I've used zfs in 5 and 7. And bcpr and bkr... They should work fine. The electrode sticks out farther than the more common bcpr or brk plugs though. The zfr plugs have a proprietary extended electrode design specified by honda. I think. Might want to double check the piston clearance if your current plug is shorter.
Old 04-13-2004, 10:16 AM
beerbongskickass's Avatar
I am using them and they work fine.
EDIT: Actually I am using the ZFR6J-11...
Old 04-13-2004, 10:29 AM
SOHC_MShue's Avatar
Default Re: 4291-ZFR6F-11 NGK plugs? (beerbongskickass)
whats the difference between the 6f and the 6j? Also do these plugs need to be gapped?
Old 04-13-2004, 10:53 AM
ladysman's Avatar
6F is for the 96-up cars
6J is for the OBD1 cars. I have a chart somewhere of the difference.
FYI. I made 262 on 6J plugs.
Old 04-13-2004, 11:03 AM
SOHC_MShue's Avatar
Default Re: 4291-ZFR6F-11 NGK plugs? (ladysman)
what if I am running an obd1 conversion?
Old 04-13-2004, 11:44 AM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">what if I am running an obd1 conversion?</TD></TR></TABLE>
I would use for what is designed for the motor. That is what I meant by the above.
If you have a Y8 use the 6F
If you have a Z6, use the 6J.
Old 04-13-2004, 08:30 PM
SOHC_MShue's Avatar
alright cool. I picked up a set today . Thanx guys. Also where do you think I should gap them at?
Old 04-14-2004, 08:15 AM
ladysman's Avatar
MSD OR no MSD?
Old 04-14-2004, 10:00 AM
SOHC_MShue's Avatar
no msd
Old 04-14-2004, 03:24 PM
92accordjdmh22aturbo's Avatar
hi, i'm gona be setting up a turbo for my JDM h22a i was just wondering what NGK plugs i should be running? if anyone has any ideas on this... it would be much apreciated!! thanks.
Old 04-15-2004, 05:37 AM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">no msd</TD></TR></TABLE>
.032
Old 04-15-2004, 09:01 AM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman &raquo;</TD></TR><TR><TD CLASS="quote">
.032</TD></TR></TABLE>
thanx man
Old 04-15-2004, 09:40 AM
ladysman's Avatar
thanx man </TD></TR></TABLE>
anytime. You could probably use .035 and be fine. Try it.
Old 04-15-2004, 10:00 AM
SOHC_MShue's Avatar
cool i'll try it out man.
OneCrzySetup
11-17-2006 11:53 AM
josephshark
10
12-15-2005 01:39 PM
Phatch99
09-08-2005 12:39 PM
PrecisionH23a
09-29-2004 08:22 AM
LSVTEC 91 Civic
05-16-2004 04:24 PM
Quick Reply: 4291-ZFR6F-11 NGK plugs?
