My car idles high after changing intake manifold
Old Aug 19, 2006 | 07:24 PM
vc's Avatar
vc
Default My car idles high after changing intake manifold
Modified by vc at 6:40 PM 8/28/2006
Old Aug 19, 2006 | 11:24 PM
Takumi Fujiwara's Avatar
Default Re: My car idles high after changing intake manifold (vc)
check for vacuum leaks.
Old Aug 19, 2006 | 11:40 PM
Jason-'s Avatar
If it idles at 2000rpms, check to make sure the throttle cable isnt SLIGHTY pulled. Loosen it up so it just kinda sits there and start her up.
-Jason
Old Aug 20, 2006 | 12:47 AM
Default Re: (Jason-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jason- &raquo;</TD></TR><TR><TD CLASS="quote">If it idles at 2000rpms, check to make sure the throttle cable isnt SLIGHTY pulled. Loosen it up so it just kinda sits there and start her up.
-Jason</TD></TR></TABLE>
If the cable is too tight, you can get a surging idle as well...
Old Aug 20, 2006 | 08:36 PM
Have you tried resetting your base idle?
Old Aug 21, 2006 | 01:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vc &raquo;</TD></TR><TR><TD CLASS="quote">how?
I tried turning the **** on the throttle body with a screwdriver.</TD></TR></TABLE>
Did you unplug the IACV when you did this?
Old Aug 22, 2006 | 02:18 PM
If you have the IACV unplugged, and if no matter how much you turn your base idle screw the idle will not drop down to about 450-500, you have a vacuum leak.
Old Aug 22, 2006 | 02:19 PM
Default Re: My car idles high after changing intake manifold (Takumi Fujiwara)
If you're OBDI, it can also be the internals of your FITV backing out...
Hackura
Mar 12, 2009 03:17 PM
tbuck23
Apr 5, 2007 05:00 PM
gtowni3
16
Oct 9, 2004 10:53 AM
dAng! Kris
Jul 22, 2004 03:13 PM
stock97
Aug 14, 2003 10:14 PM
