blowing ecu fuse
Old Aug 19, 2006 | 12:10 AM
Jason-'s Avatar
Default blowing ecu fuse
I keep blowing the ECU fuse in the under hood fuse box. I don't get it! What could cause this?
**Jdm h22a motor. 92 cx hatchback. Should I post this in hybrid??
Could this be why my motor keeps on dying and almost lacks fuel at higher rpms? Thanks!
-Jason
Old Aug 19, 2006 | 08:33 AM
Blown90hatcH's Avatar
Default Re: blowing ecu fuse (Jason-)
How are your injectors wired up? Resistor box? Did you swap the injector clips?
Old Aug 19, 2006 | 10:36 AM
Jason-'s Avatar
I wired in a resistor box, but now I'm beginning to wonder if I wired it all wrong! And I didnt mess with the injector clips due to the engine had already been in a eg civic already... I just assumed they were good. Should I take pictures and post them?
-Jason
Old Aug 19, 2006 | 12:21 PM
Default Re: (Jason-)
There could be a number of things wrong, but last time I saw this issue on a car, the resistor box wiring had issues.
Old Aug 19, 2006 | 03:39 PM
b16 prospect's Avatar
a partner of mine just had that same problem about a week ago and come to find out it was a harness wire grounding out on the injectors. he had to trace every wire on his car
Old Aug 19, 2006 | 04:38 PM
Jason-'s Avatar
My resistor box wiring is right. I just opened up the harness and checked. Now I'll check the other wires to make sure they are connected and good.
And this problem didnt happen from the beginning, but just last night... I blew 2 or 3 fuses within a short period of time. It loses fuel and then the car dies... check the fuse and its blown.
-Jason
Old Aug 19, 2006 | 06:02 PM
Default Re: (b16 prospect)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16 prospect &raquo;</TD></TR><TR><TD CLASS="quote">a partner of mine just had that same problem about a week ago and come to find out it was a harness wire grounding out on the injectors. he had to trace every wire on his car</TD></TR></TABLE>
Exactly. I have also seen that if the wires going to the injector clips are switched within all the injectors, this will blow it as well.
Old Aug 19, 2006 | 07:23 PM
Jason-'s Avatar
Hmm.. I'll have fun tracing all the wiring now.
Any other ideas?
-Jason
Old Aug 21, 2006 | 07:33 PM
Jason-'s Avatar
TTT. Help?
-Jason
Old Aug 21, 2006 | 08:53 PM
FaceTuned's Avatar
good luck jason let me know if you get it.
Old Aug 22, 2006 | 01:30 PM
Jason-'s Avatar
Default Re: (jdmhatchness)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhatchness &raquo;</TD></TR><TR><TD CLASS="quote">good luck jason let me know if you get it.</TD></TR></TABLE>
I will. No worries. I hope its nothing SERIOUS! I actually need to get off my *** and look, but Im too tired. lol
-Jason
siguy2k
Aug 21, 2012 09:46 PM
rdssk8rcs1
Apr 10, 2008 08:52 AM
ekblacknight
Jun 20, 2005 01:35 PM
Gsr_Hybrid_theory
May 23, 2005 03:33 PM
boostin b16
Mar 2, 2003 03:03 PM
