b18b swap trouble wiring
Old Aug 18, 2006 | 03:28 PM
error's Avatar
Default b18b swap trouble wiring
i just put my b18b in my 96 hatch with a modified stock harness. i was throwing codes 7(TPS) and 54(CKF). well, i did the wiring trick mentioned here http://www.ff-squad.com/technet/ckftrick.htm only discrepency is that when i spliced wires 11 and 14, 14 was black opposite of the white wire on the above mentioned web-site.
ok. now i do not have code 54(CKF). instead i have code 7(tps) and 65- which is secondary o2 heater
im wondering if i spliced the wrong wires? any insight ?
Old Aug 18, 2006 | 05:06 PM
error's Avatar
Default Re: b18b swap trouble wiring (error)
forgot to mention i do not have a secondary o2. so it is logical for it to be throwing that code. my only problem is that it didnt throw it before.
Old Aug 18, 2006 | 07:05 PM
error's Avatar
why was pin 14 wire black???? did i cut the wrong wire? car runs like **** at 5000rpm
Old Aug 19, 2006 | 07:37 AM
error's Avatar
need some help
Old Aug 19, 2006 | 02:34 PM
error's Avatar
wow. i think i know why i was throwing that code 54. my crank pully almost flew off and my alternater belt snaped im going to try to reverse that wiring that i did. also got the idle way down after i cleaned throttlebody mating surface and tightened pully. now to just fix that code 65.
slammedvtec
Mar 26, 2008 05:12 PM
error
Aug 19, 2006 02:36 PM
soundman
Apr 30, 2004 07:25 AM
DEVIN22CBR
May 4, 2003 10:09 AM
