WTF?!? Greddy profec 2- beeps then doesnt work??!! Profec2 Users Please Read
Old Aug 18, 2006 | 12:01 PM
turbotime's Avatar
Default WTF?!? Greddy profec 2- beeps then doesnt work??!! Profec2 Users Please Read
Ok this is weird, ive been using my greddy profec b2 for a few weeks now, no issues. Randomly when i start the car it will beep 3 times, then show (lo) as usual, but when i boost it it just runs off the gate boost (8psi), i tried to change setting and they are all back at the defaults?! So I turn the gain up to 38% and it still just does gate boost - 8psi?
WTF? I thought maybe my backup fuse blew resetting the unit but my clock is still fine! What the hell?! Please help!!! I was running around on the low boost last night and the unit was working fine boosting both the lo 14psi and high 17psi settings!!
Old Aug 18, 2006 | 02:24 PM
turbotime's Avatar
up for help... just drove it again and still just gate boost even though i got gain at 38%
Old Aug 19, 2006 | 07:20 PM
dpetro1's Avatar
Default Re: (turbotime)
wow, lots of boost controller posts. i have run into the problem where the unit will reset itself to the defaults but never had a problem with it not working afterward. usually i just reinput my settings and everything is back to normal. are all the connections still good? vacuum lines good? make sure to check the top port of the wg.
Old Aug 19, 2006 | 09:11 PM
platinum00's Avatar
Default Re: WTF?!? Greddy profec 2- beeps then doesnt work??!! Profec2 Users Please Read (turbotime)
so basicly sometime is works and somtimes it doesnt? sounds like a faulty unit.
do you have the limiter setting enabled for the warning. 5th optoin i think
platinum.
Old Aug 19, 2006 | 09:51 PM
turbotime's Avatar
yeah i got i working again, i guess i was setting the GAIN instead of the SET
still pretty odd that it randomy resets itself... totally out of the blue!
guess ill dial it in from scratch again and write down the setting in case it resets again
Old Aug 19, 2006 | 09:54 PM
dpetro1's Avatar
yeah its so weird but ive had it reset itself about a dozen times in the year ive had it. i have the settings memorized now lol.
PA MATT
Jul 16, 2005 08:10 AM
SwIntegraB16
Jul 3, 2005 06:16 AM
Drkaccrd
Jun 7, 2005 09:28 PM
mod5
Sep 10, 2001 08:26 AM
