bottem end
Old Aug 18, 2006 | 04:20 AM
luder2_2vtec97's Avatar
Default bottem end
can any one tell me how strong the sleeves are in a stock f22. how much boost before it shoots a rod through the sleeve.
Old Aug 18, 2006 | 05:09 AM
khunt0012's Avatar
Meat Robot Invisible
Default Re: bottem end (luder2_2vtec97)
They're very strong. I know there are a bunch of guys on here who have more experience than me with boostin the F. However 7-8 PSI daily would be fine on a stock block. I'm sure you could boost even more then that but I'm not sure how the reliability gets.
Old Aug 18, 2006 | 06:16 AM
notoriousB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luder2_2vtec97 &raquo;</TD></TR><TR><TD CLASS="quote">can any one tell me how strong the sleeves are in a stock f22. how much boost before it shoots a rod through the sleeve.</TD></TR></TABLE>
you can have a sleeved bottom end and if you use shitty rods you can still throw a rod thru the sleeve.
that said, with good pistons/rods the F22 sleeves should be able to handle 400ish HP no problem.
1FSTNDN
12
Dec 19, 2006 07:56 PM
darkblue1998ls
Jan 19, 2006 07:42 PM
CarAudioPro
Dec 6, 2005 09:37 PM
sloweredcivic
Oct 8, 2004 08:13 AM
projectTeG
Oct 14, 2003 01:33 PM
