b20 vtec, vtec not working
Old Aug 17, 2006 | 07:30 PM
dblock91's Avatar
Default b20 vtec, vtec not working
ok so heres the rundown,
my b20-vtec is more like a b20, mainly because there is no vtec engagement, the CEL flashes only at an idle, and im using a stock p2t ecu. the oil level is good...i dont know what is going on here
someone help
Old Aug 17, 2006 | 09:18 PM
civicstar's Avatar
Default Re: b20 vtec, vtec not working (dblock91)
well, is what kinda car is it in? so i take its a SI? becuz of the p2t. hmmm well wat code is it throwing at idle? is it idling wierD?
Old Aug 25, 2006 | 02:25 PM
dblock91's Avatar
Default Re: b20 vtec, vtec not working (civicstar)
still obd2b,
its throwing both o2 sensor codes because they werent replaced, and a random misfire code.
it idles ok, but if it idles for more than a minute or so the CEL starts to flash,
Modified by dblock91 at 6:55 PM 8/25/2006
Old Aug 26, 2006 | 02:28 PM
dblock91's Avatar
anyone
Old Aug 29, 2006 | 06:55 PM
dblock91's Avatar
vtec solenoid? timing? distributor? oil level? wiring? sensors?
anyone
Old Aug 29, 2006 | 06:56 PM
dblock91's Avatar
bueller......
Old Aug 29, 2006 | 07:37 PM
dblock91's Avatar
...bueller.....
Old Aug 30, 2006 | 11:28 AM
1SiC 3DR's Avatar
i had kinda the same problem in a freinds 97 civic w/ an LS swap and the check engine light was flashing and it end ended up being the cap and rotor button, and as far as no vtec, on any obd2 or obd1 system will not let vtec engage with any CEL's on - just my lil cents worth
Old Aug 30, 2006 | 03:03 PM
charlee's Avatar
Default Re: (B162XLR8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B162XLR8 &raquo;</TD></TR><TR><TD CLASS="quote"> and as far as no vtec, on any obd2 or obd1 system will not let vtec engage with any CEL's on </TD></TR></TABLE>
Old Aug 31, 2006 | 07:10 AM
SoHc94's Avatar
i dont know why people say that. because i have my cel on and my vtec engages. cuz i can feel that ****. it engages at like 5g on a stock ecu.
Old Aug 31, 2006 | 09:51 AM
charlee's Avatar
Default Re: (SoHc94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoHc94 &raquo;</TD></TR><TR><TD CLASS="quote">i dont know why people say that. because i have my cel on and my vtec engages. cuz i can feel that ****. it engages at like 5g on a stock ecu. </TD></TR></TABLE>
thenu must be on crack or have a tampered ecu
Old Aug 31, 2006 | 12:04 PM
dblock91's Avatar
Default Re: (charlee)
alright well tonight im going to check the dizzy, the ignition timing and the solenoid, thanks for the help
Old Aug 31, 2006 | 08:05 PM
dblock91's Avatar
Default Re: (dblock91)
ok i though i had this one wrapped up but i was wrong, tonight i threw a few parts, first i changed the cap and rotor, then used a brand new right out the box vtec solenoid, and checked my ignition timing, and the **** still dont work@! i really need some help on this one
Old Sep 3, 2006 | 02:26 PM
SoHc94's Avatar
get a diagnostic.
Old Sep 5, 2006 | 03:25 PM
dblock91's Avatar
could it be the fuel pressure? i dont have an ajustable fuel pressure regulator
Modified by dblock91 at 7:37 PM 9/5/2006
Old Sep 6, 2006 | 07:24 AM
1SiC 3DR's Avatar
fuel pressure isnt gonna have much to do with it because fuel pressure will either make it run lean or rich, but i'm still curious are you still throwing a check engine light and what management are you running
Old Nov 10, 2006 | 08:33 AM
hndarcrb18c1's Avatar
Default Re: (1SiC 3DR)
Oil pump!!!!
Old Nov 16, 2006 | 08:05 PM
riskyb's Avatar
Default Re: (hndarcrb18c1)
what about engine temp, if the therm is stuck open and you dont reach operating temp the vtec will not ingauge and will run in safe mode with cel
HONDA?
15
Jan 5, 2015 07:45 AM
ilovemyb16a
12
Sep 7, 2006 10:07 AM
beaneg6
Jul 24, 2005 12:51 AM
sikek
Jul 27, 2004 09:56 AM
just_a_sohc
Dec 27, 2001 08:52 AM
