Problem with b16a2 in 99 gsr
Old Aug 17, 2006 | 10:27 AM
Andyb22g's Avatar
Default Problem with b16a2 in 99 gsr
so my swap is completely done and the test runs have not been sucessfull... runs great UNTIL its suposto crack vtec then it redlines... im getting 2 O2 sensor codes, IACV code, and intake temp code but i should be getting the IVAC code and intake air temp cause the b16 is missing some intake sensors that the gsr has... i am running a 0bd2 gsr ecu also... also my tach is not working so i am thinking there might be something wrong with rpm which might be related to the vtec crossing over???
Old Aug 17, 2006 | 12:03 PM
DC2 Mang's Avatar
Default Re: Problem with b16a2 in 99 gsr (Andyb22g)
sounds like your car is running in some sort of limp mode, the ecu is trying to protect the motor from damaging itself
the IACV and IAT plugs are the same so try to switch them around incase they are plugged into the wrong sensor
I would get all the sensors, installed and then try it, you might be able to eliminate some of the problems and see what happens after that
My Honda Blows
Apr 7, 2013 07:33 PM
My Honda Blows
Apr 6, 2013 02:13 PM
miKs
Jun 24, 2011 09:00 AM
REDEM1FTW
Jul 19, 2010 04:51 PM
mrbsponge
Mar 24, 2004 03:54 PM
