Under hood is very hot!
Old Aug 17, 2006 | 06:04 AM
TurboEM1's Avatar
Default Under hood is very hot!
Hey. I have a 1991 Crx Si with a b16a1 swap. After driving it gets extremely hot under the hood. If i pull over and put my hand on top of the hood it is very very hot. If i pop the hood everything underneath is HOT. You cant even keep your hand on the <U>intake</U> it is so hot. The valve cover, intake, intake manifold, transmission, everything is hot. I do not have a heatshield on the stock header but what happens to all the guys running ramhorn turbo manifolds? they dont have heatshields. (my car is not turbo im just saying for comparison).
I had my overflow bottle full and it slowly got lower untill it just filled the bottom and stayed there. Was this the system leveling out or am i burning some? It seems to run so hot i think the coolant is boiling and evaporating out. I smell coolant but the car is not smoking white.
What could cause everything to be hot? is this normal? Thanks
Anyway the temp guage doesnt move past normal but it is very hot under the hood.
Old Aug 17, 2006 | 07:58 AM
unknown0001's Avatar
Default Re: Under hood is very hot! (TurboEM1)
When your car is cold, check how much fluid you have in the radiator. Pour in some water and keep the rad cap off while turning on the car with fan setting for inside set on heat and the fast blowing air setting. Then keep on filling up the radiator with the cap off untill it's completely full.
Squish the upper and lower rad hose sometimes to see if it will blow out any air bubbles and keep filling water in.
Don't fill water/coolant into the overfill canister, that's only for when the coolant has to go somewhere and it will fill itself in there.
hows your engine temp inside the car?
Old Aug 17, 2006 | 08:19 AM
TurboEM1's Avatar
Default Re: Under hood is very hot! (Mr.RHTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner &raquo;</TD></TR><TR><TD CLASS="quote">When your car is cold, check how much fluid you have in the radiator. Pour in some water and keep the rad cap off while turning on the car with fan setting for inside set on heat and the fast blowing air setting. Then keep on filling up the radiator with the cap off untill it's completely full.
hows your engine temp inside the car?</TD></TR></TABLE>
When cold the level is right up to the cap. It is properly bled and has no air in the system. The car doesnt overheat its just hot under the hood. And why shouldnt i put some in the overflow? Engine temp inside? What do you mean?
Old Aug 17, 2006 | 10:30 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEM1 &raquo;</TD></TR><TR><TD CLASS="quote">
When cold the level is right up to the cap. It is properly bled and has no air in the system. The car doesnt overheat its just hot under the hood. And why shouldnt i put some in the overflow? Engine temp inside? What do you mean? </TD></TR></TABLE>
engine temp gauge I meant.
Why would you put water into the overflow bottle? doesn't the name 'overflow' mean something?
Old Aug 17, 2006 | 10:54 AM
TurboEM1's Avatar
guage always reads normal.
Old Jul 9, 2010 | 06:39 AM
95hondaAccord's Avatar
I was just wondering if this was resolved as I have the same problem. The hood is very hot and everything inside is hot but the temperature is normal on the gauge.
Old Jul 9, 2010 | 05:21 PM
fcm's Avatar
fcm
Old Fart
LOL, if he didn't get it fixed back in 06 it's a good bet it's fixed by now. 94
Old Jul 9, 2010 | 11:48 PM
chewyv's Avatar
pm4nudes
life!
Old Jul 27, 2010 | 02:01 PM
TurboEM1's Avatar
lol i just stumbled across this thread. it was normal. the car had no heatshield on the header so the whole engine bay was getting heat soaked. A b16 in an already cramped bay didnt help. There was really nowhere for the heat to go.
p.s. car was then turbo'd, driven and sold. never a problem even turbo'd.
Old Jul 28, 2010 | 07:31 AM
TOO MUCH TORQUE's Avatar
normal if you live in very hot areas
shadohconspiracy
Nov 16, 2007 09:31 PM
604mugen
Jan 3, 2006 10:55 PM
Andrew 825SM
Jun 14, 2003 02:02 PM
Boostless97Lude
Sep 7, 2002 09:04 AM
daebyuck
Feb 21, 2002 09:17 AM
