Axle Puller
Old Jul 28, 2010 | 08:49 AM
minvi's Avatar
Default Axle Puller
I'm in the middle of replacing a left front axle for the first time (97 CL). I have successfully removed the hub nut and the lower ball joint from the LCA.
Now the axle is stuck in the hub. I've beaten it with a hammer and gently applied some heat. Tonight I am going to use an axle puller.
The question is: do I need to remove the brake rotor to use the axle puller? I'm worried about the rotor becoming distorted or even broken from the force of the puller.
Thanks!
Tim
Old Jul 28, 2010 | 11:44 AM
hondamark35's Avatar
Default Re: Axle Puller
never heard of (or needed..) an axle puller. a good soak in penetrating oil and a bigger hammer (since you're replacing it) should do the trick.
if you can do so without damaging the ABS or anything else prying between the hub and the face of the CV bell can loosen things up.
grjr
Aug 23, 2012 04:12 PM
thw_goalie
Aug 12, 2012 10:39 AM
SR20S13
Oct 14, 2011 05:01 AM
20-EM2-05
Feb 5, 2010 11:05 AM
Feb 19, 2004 08:54 PM
