Hesitation / Stalling
Old Aug 17, 2006 | 12:40 AM
Kaoz's Avatar
Default Hesitation / Stalling
I have '96 Accord with a 2.2 engine. The engine intermitted hesitates and stalls during acceleration or a constant speed. Never while idling. It only does this about 20% of the time but it is very dangerous to drive like this. You never know when you pull out into traffic what is going to happen. I changed the fuel filter and tested the fuel pressure. I took it to the Honda dealer and they said they could not duplicate the problem but recommended they change the main fuel relay for $260. I picked one up for $60 at NAPA and changed it myself (very easy) but this didn't help. I tested all the spark plug cables and changed the spark plugs. I feel very frustrated at this point not knowing what to check next. Any ideas would be appreciated.
Thanks.
Old Aug 17, 2006 | 10:03 AM
Kaoz's Avatar
Default Re: Hesitation / Stalling (Kaoz)
I also tested the egr valve today by disconnecting the vacuum hose.
Old Aug 17, 2006 | 10:46 AM
alterdcreations's Avatar
DISTRUBUTER
Old Aug 18, 2006 | 07:35 PM
Kaoz's Avatar
Default Re: Hesitation / Stalling (alterdcreations)
I took the distributor off and inspected it. I didn't see any cracks or corrosion. Any other way of testing it?
I dropped the gas tank today and inspected it. No trash or water.
Never had a problem like this that can't be diagnosed.
Old Aug 18, 2006 | 11:49 PM
BlUAc's Avatar
is your map sensor workin properly and have you cleaned the fuel injectors. And check your IACV that it is clean, just throwing ideas your way
Connorjaymes
10
May 12, 2018 07:28 PM
Egkid95
10
Dec 15, 2014 09:33 AM
BPDA77
Apr 3, 2013 04:38 PM
RadRonny
Dec 15, 2004 12:34 PM
Tij
Sep 2, 2002 04:49 PM
