Help! Oil restrictor for feed line do I need one?
Old Aug 16, 2006 | 03:00 PM
Boosteddb8's Avatar
Default Help! Oil restrictor for feed line do I need one?
Going to be running a turbonetics t3/t4 turbo
Do I need to run a oil restrictor for the feed line and if i do which do I use and where can I get one. Thanks.
Old Aug 16, 2006 | 03:32 PM
importdude2000's Avatar
for a <20 i would
atpturbo.com
or people found that mccmaster carr has a .60 fitting
that is the same
Old Aug 16, 2006 | 04:58 PM
DRAGLS's Avatar
Default Re: Help! Oil restrictor for feed line do I need one? (Boosteddb8)
If your running a -3 u don't need a restrictor
if running a -4 u need to run a .060 restrictor.
Old Aug 16, 2006 | 06:17 PM
TTT's Avatar
TTT
please don't just slap an oil resistrictor in the oil line. You need to check the oil pressure at the turbo.. then deside if you need a restrictor. Turbos like to have around 15-20 psi at idle and if you can keep it to 35-40 psi at WOT it will help with your spool. You should never have over 50 psi of oil pressure at the turbo. That much can blow oil past the seals.
Old Aug 16, 2006 | 07:49 PM
TheShodan's Avatar
Moderator
Default Re: (TTT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TTT &raquo;</TD></TR><TR><TD CLASS="quote">please don't just slap an oil resistrictor in the oil line. You need to check the oil pressure at the turbo.. then deside if you need a restrictor. Turbos like to have around 15-20 psi at idle and if you can keep it to 35-40 psi at WOT it will help with your spool. You should never have over 50 psi of oil pressure at the turbo. That much can blow oil past the seals.</TD></TR></TABLE>
Wonderful advice indeed...
Old Aug 16, 2006 | 09:14 PM
Boosteddb8's Avatar
Thanks for the help im going to use the pressure gauge to see were its at.
Old Aug 17, 2006 | 05:44 AM
blackeg's Avatar
Default Re: (Boosteddb8)
ive found a lot of the vtec cars spinning 8000-9000rpms will have well over 75 psi oil in the system.
id get a restrictor regardless, theres no way that the pressure in your feed line is gonna be half that of the motor, and it will save your seals some trouble
Old Aug 17, 2006 | 05:51 AM
TTT's Avatar
TTT
Default Re: (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">ive found a lot of the vtec cars spinning 8000-9000rpms will have well over 75 psi oil in the system.
In the oil system and AT the turbo are two different things.
Old Aug 17, 2006 | 06:17 AM
miller's Avatar
there is an easy solution to, place a t fitting with a mechanical pressure gauge at the turo oil feed inlet and see what kind of pressure you are seeing at the chra itself.
also,just becasue you are using a -3 line dosent mean you dont need a restrictor.
Old Aug 17, 2006 | 09:34 AM
TURBOFTW's Avatar
Default Re: (miller)
We run -3 line, and no restrictor on every turbo we run with no problems....
Old Aug 17, 2006 | 10:54 AM
Speed Infliction's Avatar
Default Re: (PeakBOOST)
i thought that the -3an had more pressure than the -4an, therefor need to be resticted ever before the -4an would. anybody have any thoughts on that.
Old Aug 17, 2006 | 02:28 PM
Boosteddb8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PeakBOOST &raquo;</TD></TR><TR><TD CLASS="quote">We run -3 line, and no restrictor on every turbo we run with no problems....</TD></TR></TABLE>
You have no problem with -3 line with both BB and non BB turbos?
Old Aug 17, 2006 | 02:32 PM
TURBOFTW's Avatar
Correct....No matter what everyone has there own opionion so even though i say dont run a restrictor some will say to run them...
Old Aug 17, 2006 | 02:35 PM
Boosteddb8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PeakBOOST &raquo;</TD></TR><TR><TD CLASS="quote">Correct....No matter what everyone has there own opionion so even though i say dont run a restrictor some will say to run them...</TD></TR></TABLE>
Thanks for the info, im just going to run a gauge on it just to be on the safe side and know for sure were the pressure its at. Cuz I have already lost my first turbo due to the seals blowing out.
carlos8
Sep 7, 2011 01:08 AM
hondahead'
Nov 11, 2009 03:59 PM
screen_name
Apr 23, 2005 07:22 AM
blufke
Nov 4, 2002 10:25 AM
slingshotsi
Sep 9, 2001 06:11 PM
