Need to get B16swap running ASAP
Old Aug 16, 2006 | 02:35 PM
frog37_'s Avatar
Default Need to get B16swap running ASAP
i have a b16 (from 99-00 SI) currently in my 1995 civic sedan. Right now the car does not want to stay running after it has been started.
It does not have an 02 sensor, but that has not kept it from running in the past.
When it does start it will not idle, it just dies, but you can keep it running by keeping your foot on the gas. I dont know where to go from here.
Old Aug 16, 2006 | 03:20 PM
hatchi's Avatar
Default Re: Need to get B16swap running ASAP (frog37_)
turn the dist a little bit and see if that will keep it idled.
Old Aug 16, 2006 | 03:26 PM
frog37_'s Avatar
Default Re: Need to get B16swap running ASAP (hatchi)
pardon the ignorance but what is the "DIST" - are you talking about the distributor?
Old Aug 16, 2006 | 03:33 PM
turbociviccoupe's Avatar
distributer...is there black smoke when you start it?
Old Aug 16, 2006 | 03:49 PM
frog37_'s Avatar
Default Re: Need to get B16swap running ASAP (turbociviccoupe)
it starts just fine - it just wont idle once started, unless you keep the rpm's up with the gas peddal, it'll die
Old Aug 16, 2006 | 08:01 PM
Laosakademiks's Avatar
a buddy of mine had the exact same problem. it was his ecu, he switched it out and it idled fine, so try changing your ecu to see if itll help
Old Aug 17, 2006 | 07:43 PM
frog37_'s Avatar
Default Re: Need to get B16swap running ASAP (Laosakademiks)
unfortunately its not like i just have a bunch of extra ECU's laying around!!! Those things are slightly expensive
Old Aug 17, 2006 | 08:43 PM
modifiedmcs's Avatar
try adjusting the little 2.5 mm allen for the throttle stop to increase rpm. (temp fix)
Old Aug 17, 2006 | 09:26 PM
95DxSi-R2
Guest
Posts: n/a
Default Re: Need to get B16swap running ASAP (modifiedmcs)
oh jesus
Old Aug 17, 2006 | 09:31 PM
Syndacate's Avatar
Default Re: Need to get B16swap running ASAP (95DxSi-R2)
I'd try turning up the idle a bit...it's a little thin nitch like a flathead screw (though not wide enough for a regular flathead to fit in), you can use a screw driver or mini flathead, just push and turn it to the left like half a turn, see if that does the trick.
Oh, btw, the idle screw is on the front of the throttle body (front being facing the intake arm, opposite the IM)
EDIT:
PS: After that I'd try putting an O2 sensor on...just see what happens...
Old Aug 20, 2006 | 09:40 AM
frog37_'s Avatar
Default Re: Need to get B16swap running ASAP (Syndacate)
i have an o2 sensor on order, im just waiting for it to come in - hopefully that'll solve my problems
Spawne32
Jul 9, 2011 05:08 AM
TweedZ
May 17, 2009 10:24 AM
xfrankx
Aug 26, 2006 08:57 AM
PM-Performance
Mar 6, 2004 06:53 AM
