wobbly Speedo needle! how to fix?
Old Aug 16, 2006 | 09:18 AM
1_slow_crx's Avatar
Default wobbly Speedo needle! how to fix?
so while doing my b16 swap i noticed i didnt have a speedo calbe so i bought one..
eveyrthing is fine til a few days ago i started to noticed it would move ever so slightly around 50-60mph...
todays i noticed when i first take off the speedo jumps from 0 to 10 then back to what i asume to be the actually speedo (5mph) and goes back to normal for a little then begins to wabble at random speeds...
what can i do?
Old Aug 16, 2006 | 10:06 AM
Mr. Giggles's Avatar
Default Re: wobbly Speedo needle! how to fix? (1_slow_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1_slow_crx &raquo;</TD></TR><TR><TD CLASS="quote">so while doing my b16 swap i noticed i didnt have a speedo calbe so i bought one..
what can i do? </TD></TR></TABLE>
The same thing is happening with me right now, only mine does it from 0-30 then it stops.. which is kinda weird, but just make sure your cable is pushed down all the way in the VSS..If that doesn't work then idk because iv posted on here and still no one has determined why this is happening?
You could try taking it out and soaking the actual cord that comes out of the plastic piece in oil and then putting it back in the tube and reinstalling it...
I will not be doing this because i had a hella time trying to get that bish through the firewall.. =/
Old Aug 16, 2006 | 11:17 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: wobbly Speedo needle! how to fix? (SmrCRX)
A common cause of this is lack of lubrication..
The cable starts to bind,twists up,and then releases causing the
speedometer needle to fluxuate.
There are some pics in this thread to explaining
how to grease the cable:
https://honda-tech.com/zerothread?id=1325930
Old Aug 16, 2006 | 02:24 PM
GoFastTshirts.com's Avatar
Default Re: wobbly Speedo needle! how to fix? (88DXCRX)
i had this problem untill i changed my vss cable try lubing it and if that doesn't work replace it
Old Aug 16, 2006 | 03:04 PM
1_slow_crx's Avatar
Default Re: wobbly Speedo needle! how to fix? (RexOwner)
its new.. couldnt have 250 miles on it
Old Aug 18, 2006 | 01:05 PM
might be you sensor then
stevenstixx
15
Jul 29, 2014 02:28 PM
dlaub25
Aug 9, 2008 06:21 PM
Paul-eg
27
Mar 6, 2008 11:03 AM
prettylew
23
Oct 28, 2007 09:30 AM
dchatch
Aug 20, 2007 10:41 PM
