Almost positive it's the axles
Old Aug 15, 2006 | 08:39 PM
fast_honda's Avatar
Default Almost positive it's the axles
When I swapped my engine to H22A I reused my 120,000 mile H23 axles. They made some clunks every now and then when the car downshifted (auto). Now that I've lowered the car the sound got worse and I get strong vibrations after 45mph. I launched the car while racing an eg the other day and now the clunking is with me almost always as I drive, I can feel it right below the pedals where the axles are. Yes it seems obvious to check the axles. I need some knowledgable feedback.
Oh yeah... since you can't get H22 auto axles at a parts store, will new/reman'd H23 auto axles work fine?
Old Aug 15, 2006 | 08:56 PM
petern101's Avatar
Default Re: Almost positive it's the axles (fast_honda)
they are the same. yeah i would just opt for h23 axles
Old Aug 15, 2006 | 08:57 PM
Eddiebx's Avatar
are they clunking only when accelerating?
and yes auto h23 remans will be fine.
Old Aug 16, 2006 | 06:49 AM
fast_honda's Avatar
Default Re: (Eddiebx)
They clunk when accelerating, bumps in the road, and decelerating. I think I've even heard it clunk a couple of times when I took a turn. Thanks for the help with what axles to get.
Old Aug 16, 2006 | 09:10 AM
fast_honda's Avatar
Default Re: (fast_honda)
I just raised the front end and checked the axles:
The drivers side had about 1/8" wiggle. The passenger side had no wiggle. Both wheels when turned made the clunking noise I've been hearing. So that means there isn't any grease in the joints so I need to replace my axles, correct?
Old Aug 16, 2006 | 09:43 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast_honda &raquo;</TD></TR><TR><TD CLASS="quote">So that means there isn't any grease in the joints so I need to replace my axles, correct?</TD></TR></TABLE>
You can probably get away with a new boot kit.
Otherwise, Autozone has a lifetime warranty on their axles. I have a set on both my cars, just in case you know, I decide to launch it @ 6k rpms on slicks or something. I mean, I don't know how it broke?...it just started making this noise one day!
Old Aug 17, 2006 | 07:31 PM
fast_honda's Avatar
Default Re: (Finest)
I got both axles with lifetime warranties today, along with the other necessities: tranny fluid, jack stands, and 36mm axle socket.
Now I'm just wondering how the heck I'm going to get that axle nut off since it's torqued to 181 ft-lbs. My air compressor is small and only goes to about 120 ft-lbs so that's probably out of the question. I do have a huge wrench I could use though. This is where I would like you guys to chime in with advice.
Also...I passed on borrowing the $202 balljoint breaker, but I heard a hammer works fine. I'm going to start searching now, but feel free to give me advice.
Old Aug 17, 2006 | 07:35 PM
v4lu3s's Avatar
RTFM
compressors dont have any measure in ft/lbs....
its your impact gun that has a torque rating.
Old Aug 17, 2006 | 07:40 PM
fast_honda's Avatar
Default Re: (v4lu3s)
You know what, you're exactly right and I must have had a brain fart. I meant PSI and that's totally different.
Old Aug 18, 2006 | 04:48 AM
Eddiebx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast_honda &raquo;</TD></TR><TR><TD CLASS="quote">You know what, you're exactly right and I must have had a brain fart. I meant PSI and that's totally different. </TD></TR></TABLE>
no you didn't
u dotn really need a compressor to get htat nut off, just park the car take off the hubcap and get a 1/2" breaker bar and a long *** pipe and loosen it.
if the cars starts rolling, have someone press the brake.
Old Aug 18, 2006 | 05:57 AM
fast_honda's Avatar
I just tried to break it loose and the car just rolled back and forth a little. Good thing my friend is off work today, I've never had any help with working on my car before, so now I can have someone press the brakes. And I have a wussy 1.5' bar, so I need to find some way to extend it.
Anyways, don't worry, I'm not going to be posting every step I take with this, I know it's been posted a couple dozen times. Thanks for the advice.
OEMJDM
Nov 26, 2006 04:00 PM
IntegR
May 7, 2006 03:41 PM
94SuperLudeSI
Mar 6, 2006 08:18 PM
Entaka
Feb 21, 2005 07:36 PM
dunkd
Jan 3, 2004 06:45 PM
