Autozone axles? stifff
Old Dec 30, 2003 | 05:11 PM
dunkd's Avatar
Default Autozone axles? stifff
both of my axles are autozone lifetime warrantied... driver side one went after 2000 miles and the other one had a wabble at full throttle so i decided to replace it...
anyway point is the one i am replacing it with is very stiff on the hub end, where it rotates around. a friend told me az axles are known for this but it will be fine just put it in. anyone ever have these problems with autozone axles?
Old Dec 30, 2003 | 06:16 PM
lilredhatch's Avatar
Default Re: Autozone axles? stifff (dunkd)
I've got Advance Auto Parts axles after breaking both mine at seperate times. There probably the same as Auto. They ride just fine and seem to be stronger than factory ones
Old Dec 31, 2003 | 08:51 AM
blackeg's Avatar
Default Re: Autozone axles? stifff (lilredhatch)
my autozone axles were a little stiff at the hub end. more than stock but you could still move them.
Old Dec 31, 2003 | 09:48 AM
B18C2_sedan's Avatar
autozone axles have always worked for me. And free lifetime replacement, whats wrong with that.
Old Dec 31, 2003 | 09:57 AM
Kendall's Avatar
Just be sure not to take the axles back too many times or they'll pull some bullshit about the warranty and refuse to replace them. Of course then you go to a different AutoZone and do the same thing.
Old Dec 31, 2003 | 04:52 PM
MAD SOHC's Avatar
I had the same problem only mine broke as soon as left the driveway. I got another one, but I took it back because it was so stiff it would have done the same thing. Thanks to autozone it now takes a day to change an axle.
Old Dec 31, 2003 | 06:06 PM
Bailhatch's Avatar
Default Re: Autozone axles? stifff (MAD SOHC)
most remaned axels are stiff like that. Never had a problem here.
Old Dec 31, 2003 | 06:18 PM
Grease Monkey's Avatar
Default Re: Autozone axles? stifff (Bailhatch)
i have autozone axles and havent had a problem yet.... seem to be pretty good and plus its a lifetime warranty...
Old Jan 1, 2004 | 12:55 PM
blackeg's Avatar
Default Re: (dc231)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc231 &raquo;</TD></TR><TR><TD CLASS="quote">Just be sure not to take the axles back too many times or they'll pull some bullshit about the warranty and refuse to replace them. Of course then you go to a different AutoZone and do the same thing.</TD></TR></TABLE>
when i brought them the first axle i broke( i actually snapped the metal rod in half, not broken at the cv joint) the guy just looked at me funny and i said dont even ask hahah. i think ive gotten like 4 autozone axles in the past 2 months- 2 of the same side on my civic and both sides for my mazda protege
Old Jan 2, 2004 | 07:47 AM
DSPDA3's Avatar
My passenger side axle is going south, and needs to be changed soon. However the driver side axle is fine. Should I change both, or just swap out the problem axle?
Old Jan 2, 2004 | 08:45 AM
Shakes's Avatar
space cadet
Default Re: Autozone axles? stifff (89STS)
just *** an FYI...
i know that at least two years ago autozone used the same exact axles that are at NAPA. so if one is out try the other.
Old Jan 2, 2004 | 10:38 AM
irev210's Avatar
Default Re: Autozone axles? stifff (shakes)
The thing I noticed with reman'd axles is you win or lose.
Im a big fan of them because of the lifetime warrenty, but its like you'll put one and it will be ****, or perfect. About how stiff they are, thats actually good, close tolerances. Once u drive around for awhile and pull them back out ull notice that they are normal. But yah i've bought reman'd axles that clicked to all hell like 2k miles after I put them in. Warrenty kicks ***.
Old Jan 2, 2004 | 12:51 PM
DSPDA3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89STS &raquo;</TD></TR><TR><TD CLASS="quote">My passenger side axle is going south, and needs to be changed soon. However the driver side axle is fine. Should I change both, or just swap out the problem axle?</TD></TR></TABLE>
Suggestions?
Old Jan 2, 2004 | 12:54 PM
irev210's Avatar
just change the problem axle..
Old Jan 3, 2004 | 06:45 PM
dunkd's Avatar
Default Re: Autozone axles? stifff (irev210)
it would be double the work to do both, doesnt benefit anything to do them both... just do the one axle.
aj_scribble
Apr 24, 2008 06:39 PM
OEMJDM
Nov 26, 2006 04:00 PM
IntegR
May 7, 2006 03:41 PM
