boost leak test
Old Aug 15, 2006 | 07:10 PM
Toanz's Avatar
Default boost leak test
I've tried searching "boost leak test" but found no results.
I was wondering, how do i perform a boost leak test?
Old Aug 15, 2006 | 07:16 PM
Frozen E's Avatar
H-T White Ops
interesting. I wanna know too.
One way I can think of is to tape a hose to your charge pipe, hook the other end up to the outloet of a shop vac.
Turn it on and check for leaks with a dish soap/water solution around all your couplers.
Old Aug 15, 2006 | 07:19 PM
platinum00's Avatar
Default Re: boost leak test (Toanz)
Get a 2.5 inch PVC cap from any hardware store, and drill a hole in the end of it. Glue a bike pump fitting in the hole you just created and make sure you have no leaks.
Use a standard coupler to fit the PVC cap on the hot side of your intercooler. Pump it up with a bike bump. Listen for leaks.
platinum.
bigD
Feb 7, 2009 06:47 AM
dartonh22
Sep 5, 2008 12:39 PM
lovey408
Jun 29, 2008 11:52 PM
LST2
Nov 15, 2005 10:09 AM
-[95cxhatch]-
Apr 23, 2004 01:23 AM
