boost leak test
H-T White Ops
interesting. I wanna know too.
One way I can think of is to tape a hose to your charge pipe, hook the other end up to the outloet of a shop vac.
Turn it on and check for leaks with a dish soap/water solution around all your couplers.
Re: boost leak test (Toanz)
Get a 2.5 inch PVC cap from any hardware store, and drill a hole in the end of it. Glue a bike pump fitting in the hole you just created and make sure you have no leaks.
Use a standard coupler to fit the PVC cap on the hot side of your intercooler. Pump it up with a bike bump. Listen for leaks.
platinum.
platinum.
lovey408
06-29-2008 11:52 PM
