HELP! no boost!
Old Apr 22, 2004 | 10:26 AM
-[95cxhatch]-'s Avatar
Default HELP! no boost!
ok just finished my setup and cranked over the motor, runs good but theres a prob the turbo is making no boost!! I've checked over all my charge pipe connections they all look good. The only thing I can come up with is my "downpipe" my real downpipe isnt made yet could this be y i'm not making anyboost?
Here is my exhaust
here is my setup
Old Apr 22, 2004 | 10:37 AM
help!
Old Apr 22, 2004 | 10:45 AM
hulkhb's Avatar
Default Re: (92lxsedan)
you drove the car around, right ? If your not boosting you have a charge pipe leak, or a severe hole in a pipe. the exhaust wont make you not boost.
Old Apr 22, 2004 | 11:00 AM
Jays91DXhatch's Avatar
Default Re: (hulkhb)
Is the wastegate on there? I just can't see the arm as it would be in the back, if it's on there, not sure why you wouldn't be seeing boost.
Old Apr 22, 2004 | 11:02 AM
LostCRX's Avatar
Default Re: HELP! no boost! (92lxsedan)
you can easily find all the leaks using air compressor or even an bike tire air pump. You're gonna slap yourself silly and ask why you didn't do this before.
Old Apr 22, 2004 | 11:03 AM
hulkhb's Avatar
Default Re: (Jays91DXhatch)
You can see it in the second pic, its a internal wg. its diagonal from the drivers headlight.
If its done right i dont think you'll need the bike pump, lol.
Old Apr 22, 2004 | 11:18 AM
i just took the charge pipe going into the TB off and reved the engine to about 3k and I could feel the pressure form the turbo blowin air out of th pipe WTF
Old Apr 22, 2004 | 11:26 AM
the wastegate is shut also
Old Apr 22, 2004 | 11:29 AM
Hoosier Daddy's Avatar
You did drive the car, right? Your boost gauge isn't going to read boost in neutral.
Old Apr 22, 2004 | 11:40 AM
MikeMAN's Avatar
Default Re: (Hoosier Daddy)
yea, you must be in gear to make boost and actually put a load on the engine
mike
Old Apr 22, 2004 | 11:53 AM
ok just took the car around the blocka few times its pushing like 1 psi MAYBE but my BOV is kina loud (type S) would it be loud under 1 psi?
Old Apr 22, 2004 | 11:54 AM
ok just took the car around the block a few it was pushing 1 PSI for about 2 seconds thats it, My bov was kinda loud (greddy type s) whenever I let off the gas WTF! would it b loud under 1 psi?
Old Apr 22, 2004 | 12:01 PM
EJ1 wilcox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92lxsedan &raquo;</TD></TR><TR><TD CLASS="quote">ok just took the car around the block a few it was pushing 1 PSI for about 2 seconds thats it, My bov was kinda loud (greddy type s) whenever I let off the gas WTF! would it b loud under 1 psi?</TD></TR></TABLE>
I really don't think the bov would be loud @ 1psi.
Is your boost gauge installed correctly?
How did your car feel? Did it feel like you were boosting?
Old Apr 22, 2004 | 12:12 PM
Tad's Avatar
Tad
is your wastegate set to stock boost?
if so you should watch out, i'm pretty sure thats 9psi,
so when you do get it boosting, make sure you dont go killing your motor or something.
whats your engine management setup?
If the wastegate is turned down some, mabye its just turned down too far,
remember the more you lower the boost the logner it'll take to spool
Old Apr 22, 2004 | 12:18 PM
its the stock wastegate i'm running the vafc hack and my enine is runninglike **** right now but i think some of it is due to having no exhaust
Old Apr 22, 2004 | 12:48 PM
bumpage i need help
Old Apr 22, 2004 | 12:51 PM
EJ1 wilcox's Avatar
What kind of turbo are you running? If it's used are you sure it's spinning like it should be?
If the wastegate is cool, the charge piping and intercooler have no leaks, it must be the turbo?
I don't know, that's all I could think of
Old Apr 22, 2004 | 01:08 PM
Default Re: (koreanwilcox)
turbo spins fine maybe i have a **** wastegate
Old Apr 22, 2004 | 01:21 PM
MikeMAN's Avatar
when you were boosting did it feel like a substantial increase in power? or not really anything..besides the noise?
i would check ur boost gauge, if it DID feel like a substancial increase.
mike
Old Apr 22, 2004 | 01:46 PM
i tightened my bov some and my boost gauge will spike up to 4psi now but it dosent really feel like that much more power i overtightrend my BOV and pulled the stud out of the top of it DAMMIT its not my day
Old Apr 22, 2004 | 03:22 PM
MikeMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92lxsedan &raquo;</TD></TR><TR><TD CLASS="quote">i tightened my bov some and my boost gauge will spike up to 4psi now but it dosent really feel like that much more power i overtightrend my BOV and pulled the stud out of the top of it DAMMIT its not my day</TD></TR></TABLE>
dont worry dude, you will get everything squared away...my car has been a bitch lately too
mike
Old Apr 22, 2004 | 04:24 PM
thanks man the only thing i can figure out is that it has to be something with my wastegate. I'm going to wait until I get my downpipe mounted up my neighbors are probly pissed off at me as it is. my car is REALLY loud
Old Apr 22, 2004 | 04:49 PM
hotintegranights's Avatar
Default Re: (MikeMAN)
im in the same dilema, just finished putting on the downpipe and still no boost
Old Apr 22, 2004 | 05:01 PM
greekspeed's Avatar
a common problem on dsm's that have internal wastegates on their stock turbos is that the pin that holds in the actuator arm for the wastgate comes off and the wastegate just stays open, not allowing the car to boost...
this happend to a friend of mine with a stock turbo 91 tsi. he jsut replaced the missing part so that the wastgate could not open freely (with out sensing boost), and the problem was fixed.
EDIT: looks like you might hae already checked what i sugested.
might be a dumb question... but do you have a gasket inbetween the blow off valve and charge pipe?
Old Apr 22, 2004 | 06:12 PM
yea I have a gasket between the bov and pipe, the pin you are talking about is it the cotter pin that holds hte wastegate arm onto the flapper?
